Upload ploblem
i've just bought a Genuino UNO, the first thing that i did was to try my new Genuino whit the blink example. but when i try to upload it i get this error:
Arduino:1.6.8 (Windows 10), Scheda:"Arduino/Genuino Uno"
Lo sketch usa 1.066 byte (3%) dello spazio disponibile per i programmi. Il massimo è 32.256 byte.
Le variabili globali usano 9 byte (0%) di memoria dinamica, lasciando altri 2.039 byte liberi per le variabili locali. Il massimo è 2.048 byte.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x47
Can someone help me?
Have you got the correct Programmer and Port configured? Tools menu
yes , port and programmer are correct.
but i get this error
Do the loopback test (sticky thread in this section for instructions), does that work?
i did the test : when i send something to the board the RX led flashes , but i don't see what i've sent to the board back on the serial monitor
Perhaps a step back. Your original post said you were getting errors, is this still the case?
As far as I know the basic Blink sketch DOES NOT output anything to the serial port. Also, the serial port doesn't show anything during uploading of sketches, you should just get detail s in the 'black output window' at the bottom of the IDE. You should see "Compiling Sketch".....'Uploading' followed by 'Done Uploading'.
Failed loopback test is a bad sign, particularly since one light is flashing but the other isn't... Are you sure wires are making good contact and all?
In that configuration... it shouldn't be possible for one light to flash, and the other not....
PHILinUK:
I don't think you read his post? He was reporting the error shown in the black output window when he clicked upload, to try to upload blink...
Or that's what I'm getting from reading his post.
Hey DrAzzy...as much as you might be right....he actually said: 'but i don't see what i've sent to the board back on the serial monitor'.....
DrAzzy:
that's correct.
DrAzzy:
i did the test again, nothing. i did make sure that wires are in good contact, nothing. changed the wires, nothing.
PHILinUK:
the serial monitor was for the loopback test , it has nothing to do whit the blink sketch
