Upload Problem Blink
Ich hatte beim Upload auf mein Arduino UNO mit Ethernet Shield Probleme.
Nun habe ich versucht den IDE Blink auf mein UNO (Nur UNO, ohne Shield und ohne jegliche verkabelung) zu laden und folgende Fehlermeldung erhalten:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dario\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\dario\AppData\Local\Temp\arduino_build_240844 -warnings=none -build-cache C:\Users\dario\AppData\Local\Temp\arduino_cache_577896 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dario\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\dario\AppData\Local\Temp\arduino_build_240844 -warnings=none -build-cache C:\Users\dario\AppData\Local\Temp\arduino_cache_577896 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\sketch\\Blink.ino.cpp" -o "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\sketch\\Blink.ino.cpp" -o "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\dario\AppData\Local\Temp\arduino_cache_577896\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/Blink.ino.elf" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844\\sketch\\Blink.ino.cpp.o" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/..\\arduino_cache_577896\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/Blink.ino.elf" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/Blink.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/Blink.ino.elf" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/Blink.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_240844/Blink.ino.elf"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\dario\AppData\Local\Temp\arduino_build_240844/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM3": Zugriff verweigert
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
hörst du ein deutliches Bling / Blong wenn du den Arduino ansteckst bzw. absteckst?
Wenn der Arduino angesteckt ist - siehst du eine Serielle Schnittstelle im Gerätemanager? Ist es wirklich die com3?
Das hat mit Deinem jetzigen Problem wohl nichts zu tun, kann Dir aber trotzdem Probleme bereiten.
Unter Umständen liefern Bauteilanschlüsse des Ethernet-Shield mit der Umhüllung des USB-Anschlusses einen Kurzschluss. Da am Besten etwas isolierendes drauf kleben.
Gruß Tommy
Wenn es die richtige Schnittstelle ist, würde ich eher auf ein noch irgendwo offenes zweites Terminal tippen; also HTerm, putty, TeraTerm oder eine zweite offene IDE mit seriellem Monitor.
Das gibt eher ein busy.
Gruß Tommy
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dario\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\dario\AppData\Local\Temp\arduino_build_690669 -warnings=none -build-cache C:\Users\dario\AppData\Local\Temp\arduino_cache_898314 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dario\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\dario\AppData\Local\Temp\arduino_build_690669 -warnings=none -build-cache C:\Users\dario\AppData\Local\Temp\arduino_cache_898314 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\sketch\\Blink.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\sketch\\Blink.ino.cpp" -o "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\sketch\\Blink.ino.cpp" -o "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\sketch\\Blink.ino.cpp.o"
Compiling core...
Using precompiled core: C:\Users\dario\AppData\Local\Temp\arduino_cache_898314\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/Blink.ino.elf" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669\\sketch\\Blink.ino.cpp.o" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/..\\arduino_cache_898314\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/Blink.ino.elf" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/Blink.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/Blink.ino.elf" "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/Blink.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\dario\\AppData\\Local\\Temp\\arduino_build_690669/Blink.ino.elf"
An error occurred while uploading the sketch
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\dario\AppData\Local\Temp\arduino_build_690669/Blink.ino.hex:i
         Using Port                    : COM3
Die richtige Schnittstelle habe ich ausgewählte. Der Arduino UNO ist im Gerätemanager sichtbar. Dennoch funktioniert der Upload nicht mehr.
Hallo
ich erhalte diese Fehlermeldung
wenn ich ein Terminalprogramm auf dem gleichen Port laufen hab.
Paul
paulpaulson:
ich erhalte diese Fehlermeldung wenn ich ein Terminalprogramm auf dem gleichen Port laufen hab.
Bei mir, in der Situation, auch:
ser_open(): can't open device "\.\COM9": Zugriff verweigert
Wenn ich dann allerdings einen seriellen Monitor öffne:
Fehler beim Öffnen des seriellen Ports "COM9". (Port busy)
manchmal hilft auch die AEG-Methode
  • Ausschalten
  • Einschalten
    -Geht
Ha ha - oder auch (aus alten DOS-Zeiten): Reboot tut immer gut!
AEG hat leider auch nicht funktioniert
daweschido:
mist
probiere es mal parallel mit einem zweiten Arduino am PC, vllt ist nur die USB-Port-Verwaltung auf dem PC im Hintern.
daweschido:
Ich dachte, ich hätte mich klar ausgedrückt ....
Was sagt es beim öffnen des Seriellen Monitors?
beim öffnen des seriellen Monitors kommt folgende Meldung:
Error opening serial port 'COM3'. (Port busy)
Dann ist die Wahrscheinlichkeit nahe 100%, dass irgendein anderes Programm auf dem Port rum reitet.
z.B. Bluetooth Anwendungen/Services neigen dazu.
auch evtl vorhandene CAPI Treiber/Programme
Ansonsten, evtl. falschen/veralteten Treiber geladen.
hat funktioniert, nachdem ich das Bluetooth ausgeschaltet habe, vielen Dank!
