I practiced arduino programming a bit.
Currently, I have changed modules and am trying to use a nano 33 sense. Unfortunately, when uploading I have a message that I cannot understand.
I can see my nano on the com port, but I have the impression that this is no longer the case when uploading.
There is still a doubt about the programmer because I do not know which one I should use. For the test I tried them all.
I did the test with another nano, from another mac computer, from a pc but this message is still the same.
I tried to find the solution on the forum but nothing helps.
Gastoon:
That is just showing you the progress of the upload (it's like a progress bar made out of text).
The screenshot you shared shows a successful upload, so everything is fine.
Gastoon:
The Tools > Programmer menu selection is only used when you do a Tools > Burn Bootloader or a Sketch > Upload Using Programmer. For normal uploads, the Tools > Programmer menu selection is completely ignored, so it makes absolutely no difference what you have selected.
Gastoon:
There's no problem, so no solution is needed. Now you can get back to having fun with your Nano 33 BLE. Enjoy!
