hi, i got a Hiletgo Badusb, with ardino micro, ithink all is good but when i want to upload i get this messages:
An error occurred while uploading the sketch
if you can help me in anyway, i would be very thankful
Uncheck the checkbox next to "Show verbose output during: compilation"
Check the checkbox next to "Show verbose output during: upload
Click "OK"
Sketch > Upload
After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the upload output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
rArduino : 1.8.11 Hourly Build 2019/12/02 05:33 (Windows 10), Carte : "Arduino Micro"
Le croquis utilise 5312 octets (18%) de l'espace de stockage de programmes. Le maximum est de 28672 octets.
Les variables globales utilisent 266 octets (10%) de mémoire dynamique, ce qui laisse 2294 octets pour les variables locales. Le maximum est de 2560 octets.
Redémarrage forcé en cours en 1200bps ouvert/fermé sur le port COM3
PORTS {COM3, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {COM5, } => {COM5, }
Found upload port: COM5
{runtime.tools.avrdude.path}/bin/avrdude -C{runtime.tools.avrdude.path}/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\Icaru\AppData\Local\Temp\arduino_build_55791/sketch_dec06b.ino.hex:i
java.io.IOException: Cannot run program "{runtime.tools.avrdude.path}/bin/avrdude": CreateProcess error=2, Le fichier spécifié est introuvable
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:197)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2075)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, Le fichier spécifié est introuvable
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 9 more
Une erreur est survenue lors du transfert du croquis
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
c,d
This error indicates you need to take some drastic action. Be aware this is somewhat advanced and will remove any boards you have installed via Boards Manager:
In the Arduino IDE, click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the Arduino15 (or similar name depending on OS) folder.
Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt, back up!
Restart the Arduino IDE
Verify that you can now use your board before reinstalling any packages via Boards Manager.
