I have problems uploading to the mkr1000 I cannot even upload a short code like this
The error code I get is:
Sketch uses 9928 bytes (3%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM13
PORTS {COM3, COM13, } / {COM3, COM13, } => {}
PORTS {COM3, COM13, } / {COM3, COM8, COM13, } => {COM8, }
Found upload port: COM8
C:\Users\donsmajz\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0/bossac.exe -i -d --port=COM8 -U true -i -e -w -v C:\Users\donsmajz\AppData\Local\Temp\arduino_build_146933/sketch_mar13a.ino.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Dec 20 2016 15:36:43
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:43
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.817 seconds
Write 10184 bytes to flash (160 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[============ ] 40% (64/160 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[======================== ] 80% (128/160 pages)write(addr=0x20005000,size=0x800)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x800)
[==============================] 100% (160/160 pages)
done in 0.082 seconds
Verify 10184 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 1491
checksumBuffer(start_addr=0x3000, size=0x1000) = a4a5
checksumBuffer(start_addr=0x4000, size=0x7c8) = db5
Verify successful
done in 0.008 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
Couldn't find a Board on the selected port. Check that you have the correct port selected. I
The arduino has COM13 and the arduino bootloader has COM08. However during upload the board is reset and switches to COM08 and stops.
I have tried
- reinstalling drivers : (driver date = 24-11-2015, version 1.2.3.0, Arduino LLC,) they were installed by downloading the non-administrator version of the IDE ( 1.8.8 )
- setting the device in bootloader moder /com08 before upload ( double tapping reset button)
- pressing reset during upload
- double tapping while uploading
The problem is on/off, but I suspect that the problem could be related to the board which are preloaded with a sketch which does massive output to the serial port [ serial.Print("stuff")] -
Othertimes i get this message (port busy) when uploading:
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2042)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM13'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM13; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
