hi all!
i'll explain some trouble i'm having with mega2560, trying to summarize as more as possible!
uploading the first sketch about stepper, the board worked, UNTIL once i saw some strange codes in the serial monitor window! After that, i can't upload anything on my 2560 :~
the loop-back test, doesn't work but i think there is something bad with reset, because when i connect a reset pin with a ground pin nothing happens but led flash once.
in few days, i'll got another 2560 (that i bought before these trobules XD) and i will try to:
However, I found something strange in the resistors between USB and ATMEGA 16U2 (attached image): the first one on the top, with USB power disconnected, has a "normal" ohm value, 220 ohm. With the USB plugged, it says 920-930 ohm!
I thought i can try to shortcircuit that resistor with another 220 ohm...what do you think about??
