Upload results in just blinking of internal led instead of actual project behaviour
Hi guys,
i finally managed to screw up a project so badly, that I seemed worthy to create an account. :smiley:
I am pretty sure that one of you will easily point me to my stupid mistake.
What happens is that my code uploads to my Arduino Nano just fine.
However, it will result in the arduino just blinking the internal led at 1Hz.
If you comment out the code between the following lines
// start comment out to make it work
// end comment out to make it work
everything works as expected.
I just can't find a mistake in the part of code, so I assume it to be a bit deeper. A memory or timing issues, whatever.
I would highly appreciate any hints.
My search for solutions in this forum has been successful many times. However, this time I couldn't find anything.
Maybe I was searching for wrong terms.
#include "DCF77.h"
#include <Time.h>
#include <TimeLib.h>
#include "DFRobotDFPlayerMini.h"
#include <SoftwareSerial.h>
SoftwareSerial dfSerial(3, 4);
DFRobotDFPlayerMini dfPlayer;
#define xOff 5
#define xKill 6
#define xBusy 7
bool xDone;
#include <Wire.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#define I2C_ADDRESS 0x3C
#define DCF_PIN 2
#define DCF_INTERRUPT 0
time_t time;
int AlarmHour;
int AlarmMinute;
int SongNumber;
int NapTime;
DCF77 DCF = DCF77(DCF_PIN,DCF_INTERRUPT);
SSD1306AsciiWire oled;
String blueToothVal;
unsigned long timestore;
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  pinMode(7, INPUT);
  pinMode(8, OUTPUT);
  DCF.Start();
  dfSerial.begin(9600);
  dfPlayer.volume(20);
  Wire.begin();
  Wire.setClock(400000L);
  oled.begin(&Adafruit128x32, I2C_ADDRESS);
  attachInterrupt(digitalPinToInterrupt(xKill), AlarmOff, FALLING);
  attachInterrupt(digitalPinToInterrupt(xOff), AlarmOn, RISING);
  attachInterrupt(digitalPinToInterrupt(xBusy), AlarmOn, RISING);
  if(Serial.available()) //wenn Daten empfangen werden...
    blueToothVal=Serial.readString();//..sollen diese ausgelesen werden
    Serial.print(blueToothVal);
    if (blueToothVal[0]=='t'){
      AlarmHour = (blueToothVal[1]-'0')*10 + (blueToothVal[2]-'0');
      AlarmMinute = (blueToothVal[3]-'0')*10 + (blueToothVal[4]-'0');
//      Serial.print(AlarmHour+AlarmMinute);
      blueToothVal="";
    else if (blueToothVal[0]=='n'){
      NapTime = (blueToothVal[1]-'0')*10 + (blueToothVal[2]-'0');
      Serial.print(NapTime);
      blueToothVal="";
    else if (blueToothVal[0]=='s'){
      SongNumber = (blueToothVal[1]-'0')*10 + (blueToothVal[2]-'0');
      Serial.print(SongNumber);
      blueToothVal="";
  if (millis() - timestore > 1000 ) {
    time_t DCFtime = DCF.getTime(); // ist eine neue DCF77 Zeit vorhanden
    if (DCFtime!=0)
      digitalClockDisplay();
      setTime(DCFtime);
    oled.setFont(lcdnums14x24);
    timestore = millis();
  if (((time/60) % 60) == AlarmMinute && ((time/3600) % 24) == AlarmHour && !xOff && !xDone){
    dfPlayer.play(SongNumber);
    xDone = true;
void digitalClockDisplay(){
  oled.setCursor(0,0);
  oled.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits){ // Ausgabe
  oled.print(":");
  if(digits < 10)
  oled.print('0');
  oled.print(digits);
void AlarmOff(){
  xDone = false;
  dfPlayer.stop();
void AlarmOn(){
  xDone = false;
Thank you very much!
Nils
Three external interrupts?
Can you show us the result of the compile & upload ?
Neither can I. The only thing i see is that you are using the String class, but so marginally that it shouldn't be an issue, and definitely not straight away. A solution with c-strings is of course better.
I am suspecting a memory overflow somewhere, but i can not really point my finger on it. You are using libraries that declare their objects on the Heap, so even the result of the compilation may not show you how much memory you are using.
The internal LED blinking, is weird, you have not even set the pinMode to output, are you sure it is not the power Led or the TX led blinking ?
#define xOff 5
#define xKill 6
#define xBusy 7
Does an Arduino Nano have interrupts on any of those pins ?
Exactly which Arduino board are you using ?
Thank you all! I am truly fascinated by your helpfulness.
I just learned something about interrupts here.
My Arduino Nano has them in pins 2 and 3.
Definitely not the pins I used and also not three of them.
For now, I fix that by commenting them out.
However, I get the same effect.
Here's what I get when uploading with verbose set to on.
Hope that is what was requested.
When compiling I only get a warning due to comparison between signed and unsigned integer expressions, that seems not to be a problem.
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\...\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\...\AppData\Local\Temp\arduino_build_251293/DCF77.ino.hex"
avrdude: writing flash (13838 bytes):
Writing | ################################################## | 100% 3.94s
avrdude: 13838 bytes of flash written
avrdude: verifying flash memory against C:\Users\...\AppData\Local\Temp\arduino_build_251293/DCF77.ino.hex:
avrdude: load data flash data from input file C:\Users\...\AppData\Local\Temp\arduino_build_251293/DCF77.ino.hex:
avrdude: input file C:\Users\...\AppData\Local\Temp\arduino_build_251293/DCF77.ino.hex contains 13838 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.96s
avrdude: verifying ...
avrdude: 13838 bytes of flash verified
avrdude done.  Thank you.
Yes, it is definitely the "L" LED.
PON ist steady on (as it should be).
Rx an Tx do nothing (although they should).
New hardware often comes loaded with the blink sketch which acts as you describe.
Can you upload a "hello world" sketch to the Nano and get it working?
yes, that works. As i mentioned, even the code above works if you comment out those couple lines.
So, I might be getting closer.
After commenting out these lines
//  dfSerial.begin(9600);
//  dfPlayer.volume(20);
it works.
Which seems to point to a problem regarding SoftwareSerial or some sort of interference between hardware serial and software serial.
I will keep you updated if I find out more.
Oh, and I found a couple of other bugs in the code stated above...
"It's my first day."
It works. I just don't know exactly why.
I included a lot of print statements to see what works and what doesn't.
And found out that the dfplayer mini couldn't establish a serial connection during setup.
That caused the blinking of the internal LED. I did not yet find out why the blinking occured as pin 13 is adressed nowhere.
And I also don't know, why commenting out the marked lines in my sketch made it work all of a sudden. Because the dfplayer still was not ready and therefore should have caused the same problem.
However, once I commented out the whole lines where dfplayer was used it all worked fine.
Why was dfplayer not able to connect?
First I used the 5V pin of the arduino. Needless to say the power was not enough to boost the speakers.
Then I used an external (5V) power source and supplied the arduino on the 5V pin. Still it didn't work until the Arduino itself was also plugged in via the USB cable. Probably the external power source was still too weak. Once I hooked off the speakers it all worked fine.
So one might consider this as solved.
I am still curious about the mysteries stated above. If anybody sees a possible cause I would be grateful to be enlightened.
Could it be that this is done from within the dfPlayer library ?
