Upload sketch without reset button
Hello, I try to upload sketch on Arduino pro mini with usb-ttl hw-728 ch340, it's upload ok, if I press reset button on event 'uploading' in IDE
But it's need to upload without press button, then I connect dtr pin hw-728 to rst pin arduino but nothing happen, sketch not uploading.
Can anyone help, how to do it correct? Thanks!
Does your USB to serial converter (CH340) have a DTR output? If so, connect the DTR output from the USB to serial converter to the reset pin on the Pro Mini through a 0.1uF capacitor.
auto reset
You should be able to upload without pushing the reset button.
yes, it have dtr. i connect it to rst arduino, but without capacitor
Then it won't work. You need the cap so the reset is pulsed low to cause a reset then goes back high to enable upload. Without the cap the chip is held in reset (low) so cannot upload.
Thanks! is it non-polar capacitor?
A 0.1uF ceramic capacitor is non-polar, yes.
Cool! Thanks! Now it uploading fine! :love_you_gesture:
