Upload to Attiny85 Uploading Error: exit status 1
Hello Arduino forum,
Uploading sketch to AtTiny85 using Arduino IDE V2.1.1.
Sketch strandTest_240116.ino, copied herewith below, loads successfully.
Sketch strandtest_wheel.ino, copied herewith below, returns
'Failed programming uploading error: exit status 1'
Both sketches compile ok.
Have compared the two files to find why one file loads and the other
doesn't.
Have Googled 'Failed programming uploading error: exit status 1'
but none of the solutions are pertenant. Most solutions for Uno
or other board.
Have compare the file looking for defect in strandtest_wheel.ino.
No luck.
Thanks.
Allen Pitts
******** begin strandTest_240116.ino works **********
// A basic everyday NeoPixel strip test program.
// NEOPIXEL BEST PRACTICES for most reliable operation:
// - Add 1000 uF CAPACITOR between NeoPixel strip's + and - connections.
// - MINIMIZE WIRING LENGTH between microcontroller board and first pixel.
// - NeoPixel strip's DATA-IN should pass through a 300-500 OHM RESISTOR.
// - AVOID connecting NeoPixels on a LIVE CIRCUIT. If you must, ALWAYS
//   connect GROUND (-) first, then +, then data.
// - When using a 3.3V microcontroller with a 5V-powered NeoPixel strip,
//   a LOGIC-LEVEL CONVERTER on the data line is STRONGLY RECOMMENDED.
// (Skipping these may work OK on your workbench but can fail in the field)
#ifdef __AVR__
 #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN    4
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 60
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
// setup() function -- runs once at startup --------------------------------
  // These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
  // Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  // END of Trinket-specific code.
  strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
// loop() function -- runs repeatedly as long as board is on ---------------
  // Fill along the length of the strip in various colors...
  colorWipe(strip.Color(255,   0,   0), 50); // Red
  colorWipe(strip.Color(  0, 255,   0), 50); // Green
  colorWipe(strip.Color(  0,   0, 255), 50); // Blue
  // Do a theater marquee effect in various colors...
  theaterChase(strip.Color(127, 127, 127), 50); // White, half brightness
  theaterChase(strip.Color(127,   0,   0), 50); // Red, half brightness
  theaterChase(strip.Color(  0,   0, 127), 50); // Blue, half brightness
  rainbow(10);             // Flowing rainbow cycle along the whole strip
  theaterChaseRainbow(50); // Rainbow-enhanced theaterChase variant
// Some functions of our own for creating animated effects -----------------
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
  for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
    delay(wait);                           //  Pause for a moment
// Theater-marquee-style chasing lights. Pass in a color (32-bit value,
// a la strip.Color(r,g,b) as mentioned above), and a delay time (in ms)
// between frames.
void theaterChase(uint32_t color, int wait) {
  for(int a=0; a<10; a++) {  // Repeat 10 times...
    for(int b=0; b<3; b++) { //  'b' counts from 0 to 2...
      strip.clear();         //   Set all pixels in RAM to 0 (off)
      // 'c' counts up from 'b' to end of strip in steps of 3...
      for(int c=b; c<strip.numPixels(); c += 3) {
        strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
      strip.show(); // Update strip with new contents
// Rainbow cycle along whole strip. Pass delay time (in ms) between frames.
void rainbow(int wait) {
  // Hue of first pixel runs 5 complete loops through the color wheel.
  // Color wheel has a range of 65536 but it's OK if we roll over, so
  // just count from 0 to 5*65536. Adding 256 to firstPixelHue each time
  // means we'll make 5*65536/256 = 1280 passes through this loop:
  for(long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
    // strip.rainbow() can take a single argument (first pixel hue) or
    // optionally a few extras: number of rainbow repetitions (default 1),
    // saturation and value (brightness) (both 0-255, similar to the
    // ColorHSV() function, default 255), and a true/false flag for whether
    // to apply gamma correction to provide 'truer' colors (default true).
    strip.rainbow(firstPixelHue);
    // Above line is equivalent to:
    // strip.rainbow(firstPixelHue, 1, 255, 255, true);
// Rainbow-enhanced theater marquee. Pass delay time (in ms) between frames.
void theaterChaseRainbow(int wait) {
  int firstPixelHue = 0;     // First pixel starts at red (hue 0)
  for(int a=0; a<30; a++) {  // Repeat 30 times...
      // 'c' counts up from 'b' to end of strip in increments of 3...
        // hue of pixel 'c' is offset by an amount to make one full
        // revolution of the color wheel (range 65536) along the length
        // of the strip (strip.numPixels() steps):
        int      hue   = firstPixelHue + c * 65536L / strip.numPixels();
        uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue -> RGB
      firstPixelHue += 65536 / 90; // One cycle of color wheel over 90 frames
***** end strandTest_240116.ino works **********
******** begin strandtest_wheel.ino load fails **********
#ifdef __AVR__
#endif
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
  #if defined (__AVR_ATtiny85__)
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  // End of trinket special code
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
  // Send a theater pixel chase in...
  theaterChase(strip.Color(0, 0, 127), 50); // Blue
  rainbow(20);
  rainbowCycle(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
******** end strandtest_wheel.ino load fails **********
Hi @AllenPitts. I'm going to ask you to post the full verbose output from an upload attempt.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Uncheck the box next to Show verbose output during: compilation in the "Preferences" dialog.
  3. Check the box next to Show verbose output during: ☐ upload.
  4. Click the "OK" button.
  5. Attempt an upload, as you did before.
  6. Wait for the upload to fail.
  7. You will see a "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  8. Open a forum reply here by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block icon on toolbar
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the error output from the upload into the code block.
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to post the output.
Hello ptillisch and the Arduino forum,
This the fill error output:
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\pitts\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\pitts\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\sketch\\strandtest_wheel.ino.cpp" -o nul
Alternatives for Adafruit_NeoPixel.h: [Adafruit NeoPixel@1.12.0]
ResolveLibrary(Adafruit_NeoPixel.h)
  -> candidates: [Adafruit NeoPixel@1.12.0]
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\sketch\\strandtest_wheel.ino.cpp" -o nul
Using cached library dependencies for file: c:\Users\pitts\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp
Using cached library dependencies for file: c:\Users\pitts\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\esp.c
Using cached library dependencies for file: c:\Users\pitts\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\esp8266.c
Using cached library dependencies for file: c:\Users\pitts\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\kendyte_k210.c
Generating function prototypes...
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\sketch\\strandtest_wheel.ino.cpp" -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\sketch\\strandtest_wheel.ino.cpp" -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\sketch\\strandtest_wheel.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit NeoPixel"
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "c:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel\\Adafruit_NeoPixel.cpp" -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\Adafruit_NeoPixel.cpp.o"
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "c:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel\\esp.c" -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\esp.c.o"
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "c:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel\\kendyte_k210.c" -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\kendyte_k210.c.o"
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "c:\\Users\\pitts\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel\\esp8266.c" -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\esp8266.c.o"
Compiling core...
Using precompiled core: C:\Users\pitts\AppData\Local\Temp\arduino\cores\arduino_avr_uno_028bb2c3e7d8168b196e60970fcae4b9\core.a
Linking everything together...
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.elf" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\sketch\\strandtest_wheel.ino.cpp.o" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\Adafruit_NeoPixel.cpp.o" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\esp.c.o" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\esp8266.c.o" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052\\libraries\\Adafruit_NeoPixel\\kendyte_k210.c.o" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/..\\..\\cores\\arduino_avr_uno_028bb2c3e7d8168b196e60970fcae4b9\\core.a" "-LC:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052" -lm
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.elf" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.eep"
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.elf" "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.hex"
Using library Adafruit NeoPixel at version 1.12.0 in folder: C:\Users\pitts\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel
"C:\\Users\\pitts\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\pitts\\AppData\\Local\\Temp\\arduino\\sketches\\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.elf"
Sketch uses 3392 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 41 bytes (2%) of dynamic memory, leaving 2007 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\pitts\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\pitts\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -cusbtiny  "-Uflash:w:C:\Users\pitts\AppData\Local\Temp\arduino\sketches\5C60EA2A3B073EB9733BC3CE740FB052/strandtest_wheel.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\pitts\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, https://learn.adafruit.com/usbtinyisp
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Failed programming: uploading error: exit status 1
Allen Pitts
You must configure Arduino IDE for the ATtiny85 board before attempting the "Upload Using Programmer" operation.
You have Tools > Board > Arduino AVR Board > Arduino Uno selected from the Arduino IDE menus. It might seem like that is correct in this case where you are using an Arduino Uno as a programmer, but you must configure the IDE for the target board, not for the programmer board. This is the reason why you got that upload error:
Select the correct board from the Tools > Board menu, as well as any other Tools sub-menus and then try the "Upload Using Programmer" operation again. Hopefully it will succeed this time.
Hello ptillisch and the Arduino forum.
Was sure that the status bar indicated
AtTiny25/45/85 [not connected]
But it is seen in the error message that apparently
Arduino Uno was chosen.
Changed to AtTiny25/45/85 [not connected]
and upload successful.
Thanks.
Allen Pitts
You are welcome. I'm glad it is working now.
Regards,
Per
