I have the same issue during a long time. Update has not helped. What to do?
Sketch uses 266109 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 22560 bytes (6%) of dynamic memory, leaving 305120 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM1
Connecting......................................
Select Sketch > Upload from the Arduino IDE menus.
Watch the black output panel at the bottom of the Arduino IDE window until you see this text printed:
Connecting...
Press and hold the button on your ESP32 board. β if your board has multiple buttons, you might have to do some trial and error to determine which is the one you need to press.
I have the same issue as @stormblast and have tried the steps that you've suggested, but it is still giving me this error. Do you have any alternative fixes?
Thank you!
I have the same issue, i already put capacitor 1 mikrofarad 16 V, and doesn't make any different, pls help me
WARNING: library LiquidCrystal I2C claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
Sketch uses 748093 bytes (57%) of program storage space. Maximum is 1310720 bytes.
Global variables use 44256 bytes (13%) of dynamic memory, leaving 283424 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM3
Connecting...
Sketch uses 1118085 bytes (85%) of program storage space. Maximum is 1310720 bytes.
Global variables use 39616 bytes (12%) of dynamic memory, leaving 288064 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port COM6
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - β esptool.py latest documentation
Failed uploading: uploading error: exit status 2
could u plz tell me how 2 solvse this problem?
