Upload to ESP32 slow via USB
Hello all,
below is the console output of the upload to ESP32 via USB from MacOS 10.12. (IDE 1.8.14). It is very slow and has all these '/dev/cu.usbmodemXX' in there - no clue where they are from. If I use the upload via WiFi it's faster.
Any suggestions on how to make the USB upload faster?
Thanks,
Markus
Sketch uses 840366 bytes (42%) of program storage space. Maximum is 1966080 bytes.
Global variables use 37828 bytes (11%) of dynamic memory, leaving 289852 bytes for local variables. Maximum is 327680 bytes.
Forcing reset using 1200bps open/close on port /dev/cu.SLAB_USBtoUART
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.iPhonemarkus-WirelessiAP, /dev/cu.MELOEF-MBP-1-Bluetooth-, /dev/cu.SLAB_USBtoUART, /dev/cu.usbmodem75, /dev/cu.usbmodem80, /dev/cu.usbmodem85, /dev/cu.usbmodem88, /dev/cu.usbmodem91, /dev/cu.usbmodem96, /dev/cu.usbmodem99, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.iPhonemarkus-WirelessiAP, /dev/tty.MELOEF-MBP-1-Bluetooth-, /dev/tty.SLAB_USBtoUART, /dev/tty.usbmodem75, /dev/tty.usbmodem80, /dev/tty.usbmodem85, /dev/tty.usbmodem88, /dev/tty.usbmodem91, /dev/tty.usbmodem96, /dev/tty.usbmodem99, /dev/tty.usbmodem1411, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.iPhonemarkus-WirelessiAP, /dev/cu.MELOEF-MBP-1-Bluetooth-, /dev/cu.SLAB_USBtoUART, /dev/cu.usbmodem75, /dev/cu.usbmodem80, /dev/cu.usbmodem85, /dev/cu.usbmodem88, /dev/cu.usbmodem91, /dev/cu.usbmodem96, /dev/cu.usbmodem99, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.iPhonemarkus-WirelessiAP, /dev/tty.MELOEF-MBP-1-Bluetooth-, /dev/tty.SLAB_USBtoUART, /dev/tty.usbmodem75, /dev/tty.usbmodem80, /dev/tty.usbmodem85, /dev/tty.usbmodem88, /dev/tty.usbmodem91, /dev/tty.usbmodem96, /dev/tty.usbmodem99, /dev/tty.usbmodem1411, } => {}
Uploading using selected port: /dev/cu.SLAB_USBtoUART
/Users/MEL/Documents/Arduino/hardware/espressif/esp32/tools/esptool/esptool --chip esp32s2 --port /dev/cu.SLAB_USBtoUART --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 /Users/MEL/Documents/Arduino/hardware/espressif/esp32/tools/partitions/boot_app0.bin 0x1000 /var/folders/vb/wytkrz7n2xl907826hwp_v2c0000gn/T/arduino_build_1249/Blinkie-tube-pp.ino.bootloader.bin 0x10000 /var/folders/vb/wytkrz7n2xl907826hwp_v2c0000gn/T/arduino_build_1249/Blinkie-tube-pp.ino.bin 0x8000 /var/folders/vb/wytkrz7n2xl907826hwp_v2c0000gn/T/arduino_build_1249/Blinkie-tube-pp.ino.partitions.bin
esptool.py v3.1-dev
Serial port /dev/cu.SLAB_USBtoUART
Connecting....
Chip is ESP32-S2
Features: WiFi, ADC and temperature sensor calibration in BLK2 of efuse
Crystal is 40MHz
MAC: 7c:df:a1:15:90:60
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.2 seconds (effective 428.6 kbit/s)...
Hash of data verified.
Compressed 13616 bytes to 9362...
Writing at 0x00001000... (100 %)
Wrote 13616 bytes (9362 compressed) at 0x00001000 in 0.4 seconds (effective 282.6 kbit/s)...
Compressed 840496 bytes to 559023...
Writing at 0x00010000... (2 %)
Writing at 0x00019995... (5 %)
Writing at 0x00024b93... (8 %)
Writing at 0x0003164d... (11 %)
Writing at 0x0003892e... (14 %)
Writing at 0x0003e2b2... (17 %)
Writing at 0x00044192... (20 %)
Writing at 0x00049690... (22 %)
Writing at 0x0004f5fc... (25 %)
Writing at 0x00054abf... (28 %)
Writing at 0x00059f53... (31 %)
Writing at 0x0005f2cf... (34 %)
Writing at 0x00064283... (37 %)
Writing at 0x0006923d... (40 %)
Writing at 0x0006e036... (42 %)
Writing at 0x0007324e... (45 %)
Writing at 0x000784ce... (48 %)
Writing at 0x0007d73f... (51 %)
Writing at 0x00082f5b... (54 %)
Writing at 0x0008814a... (57 %)
Writing at 0x0008d583... (60 %)
Writing at 0x0009274b... (62 %)
Writing at 0x000978c3... (65 %)
Writing at 0x0009c5ec... (68 %)
Writing at 0x000a1698... (71 %)
Writing at 0x000a663b... (74 %)
Writing at 0x000abab7... (77 %)
Writing at 0x000b0c76... (80 %)
Writing at 0x000b60d8... (82 %)
Writing at 0x000bbd0c... (85 %)
Writing at 0x000c168b... (88 %)
Writing at 0x000c7df8... (91 %)
Writing at 0x000d21f3... (94 %)
Writing at 0x000d6eec... (97 %)
Writing at 0x000dc69a... (100 %)
Wrote 840496 bytes (559023 compressed) at 0x00010000 in 10.7 seconds (effective 626.8 kbit/s)...
Compressed 3072 bytes to 129...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.1 seconds (effective 355.0 kbit/s)...
Leaving...
Hard resetting via RTS pin...
