I have a few Uno boards with bad FTDI chips so I can't program them using the normal upload process. My programs don't need the virtual serial connection so I'd like to program them using a USBtinyISP and the Upload Using Programmer feature in 1.8.13 of the IDE. When I try this I get the following:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 1970 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 50 bytes (2%) of dynamic memory, leaving 1998 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\Doug\AppData\Local\Temp\arduino_build_167363/ServoTrigger.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files
x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM4": The system cannot find the file specified.
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
processing.app.SerialException: Error opening serial port 'COM4'.
at processing.app.Serial.(Serial.java:152)
at processing.app.Serial.(Serial.java:82)
at processing.app.SerialMonitor$2.(SerialMonitor.java:132)
at processing.app.SerialMonitor.open(SerialMonitor.java:132)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:132)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2120)
at processing.app.Editor.access$1300(Editor.java:117)
at processing.app.Editor$UploadHandler.run(Editor.java:2089)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.<init>(Serial.java:141)
... 8 more
I can successfully program the bootloader without the USB port on the target board connected but using an ISP programmer to upload a sketch appears to also require the USB connection to the target board to also work. I would have thought that, if I can program the bootloader using just an ISP, I should also be able to program a sketch. Any insight into why this isn't true would be greatly appreciated.
Thanks
