hi
i have an arduino duemilanove and a atmega328 with arduino bootloader, i was trying to upload a new bootloader using the arduino and mega-isp but i always get
avrdude: AVR device initialized and ready to accept instructions
Reading | | 0% 0.00savrdude: stk500_recv(): programmer is not responding
avrdude: error reading signature data for part "ATMEGA328P", rc=-1
avrdude: error reading signature data, rc=-1
avrdude done. Thank you.
it can't read from the chip.
the atmega 328 is on the breadboard, without any extra devices. only power pins and isp pins are connected.
maybe i need an external clock?
if so, how do i simulate one with the arduino?
what are the default fuse settings?
the chip works right if connected on the arduino, but i want it to be completely stand alone.
You'll need to connect at least a 16MHz resonator or crystal to the chip as well as bypass caps (100nF = .1uF) on the power pins.
Why not just put the chip in the Duemilanove and upload the bootloader to it?
It's kind of a catch 22, the Arduino standard fuse set-up sets the fuses for using an external crystal/resonator. To change the fuse setting to use the internal 8 mhz oscillator requires a different kind of programmer I believe (high voltage programming?).
Simplest way is to just buy an inexpensive 16mhz 3 terminal resonator or crystal/caps for external standalone operation.
Yes, if your chip is a programmed with a standard Arduino bootloader it is "fused" for an external crystal/resonator.
I do not think you can do this because the chip expects a crystal/resonator on the XTAL1/XTAL2 pins. Other operating modes would allow this, but again this would require reprogramming fuses first.
You will find default fuses settings in the "board.txt" file in the Arduino/Hardware directory.
You should be able however to reprogram fuses with a standard external programmer (e.g. Mega-ISP).
