Hi everyone, I bought the 7 inch Sunton ESP32 8048s070 screen for a project and I need to display a .gif on repeat. I've been trying to set it up but I haven't had much luck with it. I made it to "work" using the "GFX Library for Arduino" by uploading the PDQgraphicstest and selecting the settings for my screen.
Now I tried to upload the .gif using SPIFFS and it did saved the file, but I can't make the screen to see it. This is the code:
#include <Arduino_GFX_Library.h>
#include "Arduino_GFX_dev_device.h"
#ifndef GFX_DEV_DEVICE
/* OPTION 2: Manual define hardware */
#include "Arduino_GFX_pins.h"
#include "Arduino_GFX_databus.h"
#include "Arduino_GFX_display.h"
#endif /* Manual define hardware */
* End of Arduino_GFX setting
#ifdef ESP32
#undef F
#define F(s) (s)
#endif
int32_t w, h, n, n1, cx, cy, cx1, cy1, cn, cn1;
uint8_t tsa, tsb, tsc, ds;
#define GIF_FILENAME "/WARNING.gif"
/* Wio Terminal */
#if defined(ARDUINO_ARCH_SAMD) && defined(SEEED_GROVE_UI_WIRELESS)
#include <Seeed_FS.h>
#include <SD/Seeed_SD.h>
#elif defined(TARGET_RP2040)
#include <LittleFS.h>
#include <SD.h>
#elif defined(ESP32)
#include <FFat.h>
#include <SPIFFS.h>
#include <SD.h>
#include <SD_MMC.h>
#elif defined(ESP8266)
#include <SD.h>
#else
#include <SD.h>
#endif
#include <AnimatedGIF.h>
AnimatedGIF gif;
File f;
int16_t display_width, display_height;
// Adjust these lines according to your screen's specification
#define TFT_BL 2
#define TFT_CS -1
#define TFT_DC 2
#define TFT_RST -1
void *GIFOpenFile(const char *fname, int32_t *pSize)
f = SD.open(fname, FILE_READ);
if (f)
*pSize = f.size();
return (void *)&f;
return NULL;
} /* GIFOpenFile() */
void GIFCloseFile(void *pHandle)
File *f = static_cast<File *>(pHandle);
if (f != NULL)
f->close();
} /* GIFCloseFile() */
int32_t GIFReadFile(GIFFILE *pFile, uint8_t *pBuf, int32_t iLen)
int32_t iBytesRead;
iBytesRead = iLen;
File *f = static_cast<File *>(pFile->fHandle);
// Note: If you read a file all the way to the last byte, seek() stops working
if ((pFile->iSize - pFile->iPos) < iLen)
iBytesRead = pFile->iSize - pFile->iPos - 1; // <-- ugly work-around
if (iBytesRead <= 0)
return 0;
iBytesRead = (int32_t)f->read(pBuf, iBytesRead);
pFile->iPos = f->position();
return iBytesRead;
} /* GIFReadFile() */
int32_t GIFSeekFile(GIFFILE *pFile, int32_t iPosition)
int i = micros();
f->seek(iPosition);
pFile->iPos = (int32_t)f->position();
i = micros() - i;
// Serial.printf("Seek time = %d us\n", i);
return pFile->iPos;
} /* GIFSeekFile() */
// Draw a line of image directly on the LCD
void GIFDraw(GIFDRAW *pDraw)
uint8_t *s;
uint16_t *d, *usPalette, usTemp[320];
int x, y, iWidth;
iWidth = pDraw->iWidth;
if (iWidth + pDraw->iX > display_width)
iWidth = display_width - pDraw->iX;
usPalette = pDraw->pPalette;
y = pDraw->iY + pDraw->y; // current line
if (y >= display_height || pDraw->iX >= display_width || iWidth < 1)
return;
s = pDraw->pPixels;
if (pDraw->ucDisposalMethod == 2) // restore to background color
for (x = 0; x < iWidth; x++)
if (s[x] == pDraw->ucTransparent)
s[x] = pDraw->ucBackground;
pDraw->ucHasTransparency = 0;
// Apply the new pixels to the main image
if (pDraw->ucHasTransparency) // if transparency used
uint8_t *pEnd, c, ucTransparent = pDraw->ucTransparent;
int x, iCount;
pEnd = s + iWidth;
x = 0;
iCount = 0; // count non-transparent pixels
while (x < iWidth)
c = ucTransparent - 1;
d = usTemp;
while (c != ucTransparent && s < pEnd)
c = *s++;
if (c == ucTransparent) // done, stop
s--; // back up to treat it like transparent
else // opaque
*d++ = usPalette[c];
iCount++;
} // while looking for opaque pixels
if (iCount) // any opaque pixels?
gfx->draw16bitBeRGBBitmap(pDraw->iX + x, y, usTemp, iCount, 1);
x += iCount;
iCount = 0;
// no, look for a run of transparent pixels
c = ucTransparent;
while (c == ucTransparent && s < pEnd)
c = *s++;
iCount++;
s--;
if (iCount)
x += iCount; // skip these
iCount = 0;
s = pDraw->pPixels;
// Translate the 8-bit pixels through the RGB565 palette (already byte reversed)
usTemp[x] = usPalette[*s++];
gfx->draw16bitBeRGBBitmap(pDraw->iX, y, usTemp, iWidth, 1);
} /* GIFDraw() */
#ifdef GFX_EXTRA_PRE_INIT
GFX_EXTRA_PRE_INIT();
#endif
// Init Display
if (!gfx->begin())
Serial.println("gfx->begin() failed!");
gfx->fillScreen(BLACK);
#ifdef GFX_BL
pinMode(GFX_BL, OUTPUT);
digitalWrite(GFX_BL, HIGH);
#endif
display_width = gfx->width();
display_height = gfx->height();
// Initialize SD card
if (!SD.begin(5)) // Change the CS pin if needed
Serial.println(F("ERROR: SD Card Mount Failed!"));
gfx->println(F("ERROR: SD Card Mount Failed!"));
gif.begin(BIG_ENDIAN_PIXELS);
#ifdef GFX_BL
#endif
void loop(void)
if (gif.open(GIF_FILENAME, GIFOpenFile, GIFCloseFile, GIFReadFile, GIFSeekFile, GIFDraw))
Serial.printf("Successfully opened GIF; Canvas size = %d x %d\n", gif.getCanvasWidth(), gif.getCanvasHeight());
GIFINFO gi;
if (gif.getInfo(&gi))
Serial.printf("frame count: %d\n", gi.iFrameCount);
Serial.printf("duration: %d ms\n", gi.iDuration);
Serial.printf("max delay: %d ms\n", gi.iMaxDelay);
Serial.printf("min delay: %d ms\n", gi.iMinDelay);
unsigned long start_ms = millis();
int iFrames = 0;
while (gif.playFrame(true, NULL))
iFrames++;
Serial.printf("total decode time for %d frames = %lu ms\n", iFrames, millis() - start_ms);
gif.close();
Serial.printf("Error opening file = %d\n", gif.getLastError());
while (1)
In Arduino_GFX_dev_device.h I have:
#elif defined(ESP32_8048S070)
#define GFX_DEV_DEVICE ESP32_8048S070
#define GFX_BL 2
Arduino_ESP32RGBPanel *rgbpanel = new Arduino_ESP32RGBPanel(
41 /* DE */, 40 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
14 /* R0 */, 21 /* R1 */, 47 /* R2 */, 48 /* R3 */, 45 /* R4 */,
9 /* G0 */, 46 /* G1 */, 3 /* G2 */, 8 /* G3 */, 16 /* G4 */, 1 /* G5 */,
15 /* B0 */, 7 /* B1 */, 6 /* B2 */, 5 /* B3 */, 4 /* B4 */,
0 /* hsync_polarity */, 180 /* hsync_front_porch */, 30 /* hsync_pulse_width */, 16 /* hsync_back_porch */,
0 /* vsync_polarity */, 12 /* vsync_front_porch */, 13 /* vsync_pulse_width */, 10 /* vsync_back_porch */);
Arduino_RGB_Display *gfx = new Arduino_RGB_Display(
800 /* width */, 480 /* height */, rgbpanel, 0 /* rotation */, true /* auto_flush */);
In Arduino_GFX_pins.h I have:
#if defined(__IMXRT1052__) || defined(__IMXRT1062__)
// PJRC Teensy 4.x
#define TFT_CS 39 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 41
#define TFT_RST 40
#define GFX_BL 22
#elif defined(ARDUINO_BLACKPILL_F411CE)
#define TFT_CS 4 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 3
#define TFT_RST 2
#define GFX_BL 1
#define TFT_CS 17 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 27
#define TFT_RST 26
#define GFX_BL 28
#elif defined(ESP32) && (CONFIG_IDF_TARGET_ESP32)
#define TFT_CS 5 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 27 // GFX_NOT_DEFINED for display without DC pin (9-bit SPI)
#define TFT_RST 33
#define GFX_BL 22
#elif defined(ESP32) && (CONFIG_IDF_TARGET_ESP32S2)
#define TFT_CS 34 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 38
#define TFT_RST 33
#define GFX_BL 21
#elif defined(ESP32) && (CONFIG_IDF_TARGET_ESP32S3)
#define TFT_CS 40 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 41
#define TFT_RST 42
#define GFX_BL 48
#elif defined(ESP32) && (CONFIG_IDF_TARGET_ESP32C3)
#define TFT_CS 7 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 2
#define TFT_RST 1
#define GFX_BL 3
#define TFT_CS 15 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 4
#define TFT_RST 2
#define GFX_BL 5
#elif defined(RTL8722DM)
#if defined(BOARD_RTL8720DN_BW16)
#define TFT_CS 9
#define TFT_DC 8
#define TFT_RST 6
#define GFX_BL 3
#elif defined(BOARD_RTL8722DM)
#define TFT_CS 18
#define TFT_DC 17
#define TFT_RST 22
#define GFX_BL 23
#elif defined(BOARD_RTL8722DM_MINI)
#define TFT_CS 12
#define TFT_DC 14
#define TFT_RST 15
#define GFX_BL 13
#else // old version
#define TFT_CS 18 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 17
#define TFT_RST 2
#define GFX_BL 23
#endif
#elif defined(SEEED_XIAO_M0)
#define TFT_CS 3 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 2
#define TFT_RST 1
#define GFX_BL 0
#else
#define TFT_CS 9 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 8
#define TFT_RST 7
#define GFX_BL 6
#endif
In Arduino_GFX_databus.h I have:
// General software SPI
// Arduino_DataBus *bus = new Arduino_SWSPI(TFT_DC, TFT_CS, 18 /* SCK */, 23 /* MOSI */, GFX_NOT_DEFINED /* MISO */);
// hardware SPI (default DataBus, comment below block if you are not using hardware SPI)
#if defined(ARDUINO_ARCH_NRF52840)
// Arduino_DataBus *bus = new Arduino_mbedSPI(TFT_DC, TFT_CS);
Arduino_DataBus *bus = new Arduino_NRFXSPI(TFT_DC, TFT_CS, 13 /* SCK */, 11 /* MOSI */, 12 /* MISO */);
Arduino_DataBus *bus = new Arduino_RPiPicoSPI(TFT_DC /* DC */, TFT_CS /* CS */, 18 /* SCK */, 19 /* MOSI */, 16 /* MISO */, spi0 /* spi */);
Arduino_DataBus *bus = new Arduino_ESP32SPI(TFT_DC, TFT_CS, 18 /* SCK */, 23 /* MOSI */, GFX_NOT_DEFINED /* MISO */, VSPI /* spi_num */);
#elif defined(ESP32) && (CONFIG_IDF_TARGET_ESP32S2 || CONFIG_IDF_TARGET_ESP32S3)
Arduino_DataBus *bus = new Arduino_ESP32SPI(TFT_DC, TFT_CS, 36 /* SCK */, 35 /* MOSI */, GFX_NOT_DEFINED /* MISO */, HSPI /* spi_num */);
Arduino_DataBus *bus = new Arduino_ESP32SPI(TFT_DC, TFT_CS, 4 /* SCK */, 6 /* MOSI */, GFX_NOT_DEFINED /* MISO */, FSPI /* spi_num */);
Arduino_DataBus *bus = new Arduino_ESP8266SPI(TFT_DC, TFT_CS);
#else
// General hardware SPI
Arduino_DataBus *bus = new Arduino_HWSPI(TFT_DC, TFT_CS);
#endif
// General Software parallel 8-bit
// Arduino_DataBus *bus = new Arduino_SWPAR8(A2 /* DC */, A3 /* CS */, A1 /* WR */, A0 /* RD */, 8 /* D0 */, 9 /* D1 */, 2 /* D2 */, 3 /* D3 */, 4 /* D4 */, 5 /* D5 */, 6 /* D6 */, 7 /* D7 */);
// General Software parallel 16-bit
// Arduino_DataBus *bus = new Arduino_SWPAR16(32 /* DC */, GFX_NOT_DEFINED /* CS */, 21 /* WR */, GFX_NOT_DEFINED /* RD */, 19 /* D0 */, 23 /* D1 */, 18 /* D2 */, 5 /* D3 */, 17 /* D4 */, 16 /* D5 */, 25 /* D6 */, 26 /* D7 */, 27 /* D8 */, 14 /* D9 */, 12 /* D10 */, 13 /* D11 */, 15 /* D12 */, 2 /* D13 */, 0 /* D14 */, 4 /* D15 */);
// Arduino UNO / UNO R4 MINIMA / UNO R4 WIFI parallel 8-bit
// Arduino_DataBus *bus = new Arduino_UNOPAR8();
// AVR PORT parallel 8-bit
// Arduino Pro Micro port 2(PB): 17, 15, 16, 14, 8, 9, 10, 11
// Arduino_DataBus *bus = new Arduino_AVRPAR8(4 /* DC */, 5 /* CS */, 18 /* WR */, 19 /* RD */, 2 /* PORT */);
// AVR PORT parallel 16-bit
// Arduino MEGA 2560
// port 3(PC): 37, 36, 35, 34, 33, 32, 31, 30
// port 1(PA): 22, 23, 24, 25, 26, 27, 28, 29
// Arduino_DataBus *bus = new Arduino_AVRPAR16(38 /* DC */, 40 /* CS */, 39 /* WR */, 43 /* RD */, 3 /* PORT LOW */, 1 /* PORT HIGH */);
// ESP32 parallel 8-bit
// Arduino_DataBus *bus = new Arduino_ESP32PAR8(TFT_DC, TFT_CS, 25 /* WR */, 32 /* RD */, 23 /* D0 */, 19 /* D1 */, 18 /* D2 */, 26 /* D3 */, 21 /* D4 */, 4 /* D5 */, 0 /* D6 */, 2 /* D7 */);
// ESP32 parallel 16-bit
// Almost all GPIO 0-31 used up for 16-bit and WR, disable PSRAM to gain 16 and 17 but still no GPIOs remain for CS and RD.
// CS connect to GND (enable); RD connect to Vcc (disable).
// Arduino_DataBus *bus = new Arduino_ESP32PAR16(
// 32 /* DC */, GFX_NOT_DEFINED /* CS */, 21 /* WR */, GFX_NOT_DEFINED /* RD */,
// 19 /* D0 */, 23 /* D1 */, 18 /* D2 */, 5 /* D3 */, 17 /* D4 */, 16 /* D5 */, 25 /* D6 */, 26 /* D7 */,
// 27 /* D8 */, 14 /* D9 */, 12 /* D10 */, 13 /* D11 */, 15 /* D12 */, 2 /* D13 */, 0 /* D14 */, 4 /* D15 */);
// ESP32 QSPI
// Arduino_DataBus *bus = new Arduino_ESP32QSPI(
// 10 /* CS */, 5 /* SCK */, 14 /* D0 */, 8 /* D1 */, 0 /* D2 */, 1 /* D3 */);
// ESP32S2 parallel 8-bit
// Display D0-D7 connect to GPIO 0-7
// Arduino_DataBus *bus = new Arduino_ESP32S2PAR8(TFT_DC, TFT_CS, 16 /* WR */, 17 /* RD */);
// ESP32S2 parallel 16-bit
// Display D0-D15 connect to GPIO 0-15
// Arduino_DataBus *bus = new Arduino_ESP32S2PAR16(TFT_DC, TFT_CS, 16 /* WR */, 17 /* RD */);
// ESP32S3 i80 LCD parallel 8-bit
// Arduino_DataBus *bus = new Arduino_ESP32LCD8(
// TFT_DC, TFT_CS, 16 /* WR */, 17 /* RD */,
// 0 /* D0 */, 1 /* D1 */, 2 /* D2 */, 3 /* D3 */, 4 /* D4 */, 5 /* D5 */, 6 /* D6 */, 7 /* D7 */);
// ESP32S3 i80 LCD parallel 16-bit
// Arduino_DataBus *bus = new Arduino_ESP32LCD16(
// 0 /* D0 */, 1 /* D1 */, 2 /* D2 */, 3 /* D3 */, 4 /* D4 */, 5 /* D5 */, 6 /* D6 */, 7 /* D7 */,
// 8 /* D8 */, 9 /* D9 */, 10 /* D10 */, 11 /* D11 */, 12 /* D12 */, 13 /* D13 */, 14 /* D14 */, 15 /* D15 */);
// Raspberry Pi Pico parallel 8-bit
// Arduino_DataBus *bus = new Arduino_RPiPicoPAR8(TFT_DC, TFT_CS, 18 /* WR */, 19 /* RD */);
// Raspberry Pi Pico parallel 16-bit
// Arduino_DataBus *bus = new Arduino_RPiPicoPAR16(TFT_DC, TFT_CS, 18 /* WR */, 19 /* RD */);
// RTL8722 parallel 8-bit
// Reduce GPIO usage: CS connect to GND (enable); RD connect to Vcc (disable); No Backlight pins.
// Arduino_DataBus *bus = new Arduino_RTLPAR8(0 /* DC */, GFX_NOT_DEFINED /* CS */, 1 /* WR */, GFX_NOT_DEFINED /* RD */, 18 /* D0 */, 22 /* D1 */, 17 /* D2 */, 20 /* D3 */, 19 /* D4 */, 23 /* D5 */, 21 /* D6 */, 16 /* D7 */);
And finally in Arduino_GFX_display.h, I have:
* Start of Canvas (framebuffer)
// #define CANVAS
// 16-bit color Canvas (240x320 resolution only works for ESP32 with PSRAM)
// Arduino_G *output_display = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// Arduino_GFX *gfx = new Arduino_Canvas(240 /* width */, 320 /* height */, output_display);
// Indexed color Canvas, mask_level: 0-2, larger mask level mean less color variation but can have faster index mapping
// Arduino_GFX *gfx = new Arduino_Canvas_Indexed(240 /* width */, 320 /* height */, output_display, 0 /* output_x */, 0 /* output_y */, MAXMASKLEVEL /* mask_level */);
// 3-bit color Canvas, R1G1B1, 8 colors
// Arduino_G *output_display = new Arduino_ILI9488_3bit(bus, GFX_NOT_DEFINED /* RST */, 1 /* rotation */, false /* IPS */);
// Arduino_GFX *gfx = new Arduino_Canvas_3bit(480 /* width */, 320 /* height */, output_display, 0 /* output_x */, 0 /* output_y */);
// Mono color Canvas
// Arduino_GFX *gfx = new Arduino_Canvas_Mono(240 /* width */, 320 /* height */, output_display, 0 /* output_x */, 0 /* output_y */);
* End of Canvas (framebuffer)
// GC9A01 IPS LCD 240x240
// Arduino_GFX *gfx = new Arduino_GC9A01(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// GC9106 IPS LCD 80x160
// Arduino_GFX *gfx = new Arduino_GC9106(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// GC9107 IPS LCD 128x128
// Arduino_GFX *gfx = new Arduino_GC9107(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// HX8347C IPS LCD 240x320
// Arduino_GFX *gfx = new Arduino_HX8347C(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// HX8347D IPS LCD 240x320
// Arduino_GFX *gfx = new Arduino_HX8347D(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// HX8352C IPS LCD 240x400
// Arduino_GFX *gfx = new Arduino_HX8352C(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// HX8357A IPS LCD 320x480 (currently only portrait works, i.e. rotation 0 and 2)
// Arduino_GFX *gfx = new Arduino_HX8357A(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// HX8357B IPS LCD 320x480
// Arduino_GFX *gfx = new Arduino_HX8357B(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// HX8369A LCD 480x800
// Arduino_GFX *gfx = new Arduino_HX8369A(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 480, 800, 0, 7, 0, 57);
// ILI9225 LCD 176x220
// Arduino_GFX *gfx = new Arduino_ILI9225(bus, TFT_RST);
// ILI9341 LCD 240x320 (default Display, comment below line if you are not using ILI9341)
Arduino_GFX *gfx = new Arduino_ILI9341(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9342 LCD 320x240
// Arduino_GFX *gfx = new Arduino_ILI9342(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9481 parallel 8/16-bit LCD 320x480
// Arduino_GFX *gfx = new Arduino_ILI9481(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9481 SPI LCD 320x480
// Arduino_GFX *gfx = new Arduino_ILI9481_18bit(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9486 parallel 8/16-bit LCD 320x480
// Arduino_GFX *gfx = new Arduino_ILI9486(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9486 SPI LCD 320x480
// Arduino_GFX *gfx = new Arduino_ILI9486_18bit(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9488 parallel 8/16-bit LCD 320x480
// Arduino_GFX *gfx = new Arduino_ILI9488(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9488 SPI LCD 320x480
// Arduino_GFX *gfx = new Arduino_ILI9488_18bit(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// ILI9806 LCD 480x854
// Arduino_GFX *gfx = new Arduino_ILI9806(bus, TFT_RST, 0 /* rotation */, false /* IPS */);
// JBT6K71 LCD 240x320
// Arduino_GFX *gfx = new Arduino_JBT6K71(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 240, 320, 0, 0, 16, 0);
// NT35310 LCD 320x480
// Arduino_GFX *gfx = new Arduino_NT35310(bus, TFT_RST, 0 /* rotation */);
// NT35510 LCD 480x800
// Arduino_GFX *gfx = new Arduino_NT35510(bus, TFT_RST, 0 /* rotation */);
// NT39125 LCD 240x376
// Arduino_GFX *gfx = new Arduino_NT39125(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 240, 376, 0, 0, 0, 56);
// NV3041A IPS LCD
// Arduino_GFX *gfx = new Arduino_NV3041A(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// OTM8009A LCD 480x800
// Arduino_GFX *gfx = new Arduino_OTM8009A(bus, TFT_RST, 0 /* rotation */);
// R61529 IPS LCD 320x480
// Arduino_GFX *gfx = new Arduino_R61529(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// SEPS525 OLED 160x128
// Arduino_GFX *gfx = new Arduino_SEPS525(bus, TFT_RST, 0 /* rotation */);
// SSD1283A OLED 130x130
// Arduino_GFX *gfx = new Arduino_SSD1283A(bus, TFT_RST, 0 /* rotation */);
// SSD1331 OLED 96x64
// Arduino_GFX *gfx = new Arduino_SSD1331(bus, TFT_RST, 0 /* rotation */);
// SSD1351 OLED 128x128
// Arduino_GFX *gfx = new Arduino_SSD1351(bus, TFT_RST, 0 /* rotation */);
// ST7735 LCD
// 1.8" REDTAB 128x160
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */);
// 1.8" BLACKTAB 128x160
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 128 /* width */, 160 /* height */, 2 /* col offset 1 */, 1 /* row offset 1 */, 2 /* col offset 2 */, 1 /* row offset 2 */, false /* BGR */);
// 1.8" GREENTAB A 128x160
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 128 /* width */, 160 /* height */, 2 /* col offset 1 */, 1 /* row offset 1 */, 2 /* col offset 2 */, 1 /* row offset 2 */);
// 1.8" GREENTAB B 128x160
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 128 /* width */, 160 /* height */, 2 /* col offset 1 */, 3 /* row offset 1 */, 2 /* col offset 2 */, 1 /* row offset 2 */);
// 1.8" Wide angle LCD 128x160
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 128 /* width */, 160 /* height */, 0 /* col offset 1 */, 0 /* row offset 1 */, 0 /* col offset 2 */, 0 /* row offset 2 */, false /* BGR */);
// 1.5" GREENTAB B 128x128
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 128 /* width */, 128 /* height */, 2 /* col offset 1 */, 3 /* row offset 1 */, 2 /* col offset 2 */, 1 /* row offset 2 */);
// 1.5" GREENTAB C 128x128
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, false /* IPS */, 128 /* width */, 128 /* height */, 0 /* col offset 1 */, 32 /* row offset 1 */);
// 0.96" IPS LCD 80x160
// Arduino_GFX *gfx = new Arduino_ST7735(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 80 /* width */, 160 /* height */, 26 /* col offset 1 */, 1 /* row offset 1 */, 26 /* col offset 2 */, 1 /* row offset 2 */);
// ST7789 LCD
// 2.4" LCD 240x320
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */);
// 2.4" IPS LCD 240x320
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// 1.9" IPS round corner LCD 170x320
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 170 /* width */, 320 /* height */, 35 /* col offset 1 */, 0 /* row offset 1 */, 35 /* col offset 2 */, 0 /* row offset 2 */);
// 1.69" IPS round corner LCD 240x280
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 240 /* width */, 280 /* height */, 0 /* col offset 1 */, 20 /* row offset 1 */, 0 /* col offset 2 */, 20 /* row offset 2 */);
// 1.47" IPS round corner LCD 172x320
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 172 /* width */, 320 /* height */, 34 /* col offset 1 */, 0 /* row offset 1 */, 34 /* col offset 2 */, 0 /* row offset 2 */);
// 1.3"/1.5" square IPS LCD 240x240
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 240 /* width */, 240 /* height */, 0 /* col offset 1 */, 0 /* row offset 1 */, 0 /* col offset 2 */, 80 /* row offset 2 */);
// 1.14" IPS LCD 135x240
// Arduino_GFX *gfx = new Arduino_ST7789(bus, TFT_RST, 0 /* rotation */, true /* IPS */, 135 /* width */, 240 /* height */, 52 /* col offset 1 */, 40 /* row offset 1 */, 53 /* col offset 2 */, 40 /* row offset 2 */);
// ST7796 LCD
// 4" LCD 320x480
// Arduino_GFX *gfx = new Arduino_ST7796(bus, TFT_RST, 0 /* rotation */);
// 4" IPS LCD 320x480
// Arduino_GFX *gfx = new Arduino_ST7796(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
// WEA2012 LCD
// #define CANVAS
// Arduino_GFX *output_display = new Arduino_WEA2012(bus, TFT_RST);
// Arduino_GFX *gfx = new Arduino_Canvas(356 /* width */, 400 /* height */, output_display);
Do you guys have any idea how I can make my .gif file appear? Thank you!
