Uploading a sketch on Arduino Uno: "stk500_getsync(): not in sync: resp=0xe0"
I’ve bought Arduino Starter Kit with Arduino Uno inside. When I was trying to upload the example with the Arduino Ide I got the following error:
My Operative System is Windows 8 but i had the same error on Windows 7 and a similar on Ubuntu(“stk500_recv() programmer is not responding”)
Drivers, type of board and port are properly set.
The Loop-Back Test test works fine.
Here is the verbose output:
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [e0]
avrdude: stk500_getsync(): not in sync: resp=0xe0
avrdude done.  Thank you.
Thanks for any help!
And is your Arduino on COM3? Do you provide loopback test? Try another USB cable? ...
This was the first reply I found after search of PL-2303 USB adapter.
Did a bit more searching and found you have to swap the RX and TX leads,hit upload then press re-set button as soon as you see the compiled sketch size (I think you have 5 seconds?)
I pressed a couple of times and got things uploaded
BTW, my adapter was on COM 6
Yes. Yes and it goes well. Yes, I tried three different cables
Did a bit more searching and found you have to swap the RX and TX leads,hit upload then press re-set button as soon as you see the compiled sketch size (I think you have 5 seconds?) I pressed a couple of times and got things uploaded BTW, my adapter was on COM 6
It doesn't work. I tried more than 5 times. It just change the code error from 0xe0 to 0x00 I can't put Arduino on COM6 because it is already on use.
However if I open the serial monitor it sends me some character at a periodic interval:
s????????,???,?????? ëÞ HÌs?
This is strange. And what about trying to change the port to COM20 in Device Manager, for example? The port COM20 certainly not occupied by anything (I hope).
I tried ports from COM15 to COM20, nothing seems to change.
If you are using another shield like Ethernet/Wifi try disconnect that shield. Then upload it using sdk. Then re-attach the shield. It solves my gtk error :slight_smile:
Thanks but I just bought the kit. There are no shields or cables attached except the USB cable ;)
