Hello All
I am trying to upload the Blink to my new Arduino Ueno R3 board. I am using a surface pro3 with the latest Windows 10. I have the correct board selected, the correct port selected.
Arduino: 1.6.6 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Is the error I get.
Totally new to all of this would like any help I can get.
"COM1" is the default when no serial port is selected. Use Tools->Port to select the correct serial port for your board. If your board does not appear in the list of serial ports you may need to install a driver.
"Com3" is the port it is using. I can see it in the control panel in ports. I have uninstalled and reinstalled the drivers several times. I am going to try it on my old Windows 7 laptop. However, I was really hoping to use my surface.
Any other suggestions?
If it is using COM3 why does the error message say avrdude: ser_open(): can't open device "\\.\COM1": The system cannot find the file specified.
Go to Preferences and turn on verbose upload logging. Maybe one of the log messages will say why it is getting a COM1 error when you select COM3.
kerrybaird:
You still need to select COM3 in the Arduino IDE. Yes, Windows know it is on COM3. Tell the Arduino software that! Go to Tools->Port in the IDE and select COM3.
