The very same Aruino upload code perfectly in the lab but not at home.
On the home PC, uploading blink, I get
avrdude: verification error, first mismatch at byte 0x000c
0x0c != 0x69
In the lab it is OK.
Lab PC - Win 7 running as administrator
Home PC - Win XP SP3 using non admin account, baud rate changed to 57600 from the 9600 the drivers installed at....
Board Arduino Duemillanove. No extra wiring on main board. Tested without proto shield (even though it works fine with it in the lab.
verbose output @ home - avrdude command is:
C:\Documents and Settings\Omar\My Documents\My Received Files\arduino-0018\hardware/tools/avr/bin/avrdude -CC:\Documents and Settings\Omar\My Documents\My Received Files\arduino-0018\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\.\COM9 -b57600 -D -Uflash:w:C:\DOCUME~1\Omar\LOCALS~1\Temp\build5815361073039737073.tmp\Blink.cpp.hex:i
Any ideas? Or should I shift everything to my admin account?
If it works on one home computer, and not on another, with the same cable and same Arduino, then it must be a driver issue on the computer that fails. Presuming, of course, that the same board is selected on each computer, and that the correct port is selected on each (which may not be the same port on each computer).
In any case, Arduino comes before kids, no matter what they say.
