Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Writing | ################################################## | 100% 0.58s
avrdude: 3252 bytes of flash written
avrdude: verifying flash memory against C:\Users\SHUBHAM\AppData\Local\Temp\arduino_build_143421/rec.ino.hex:
avrdude: load data flash data from input file C:\Users\SHUBHAM\AppData\Local\Temp\arduino_build_143421/rec.ino.hex:
avrdude: input file C:\Users\SHUBHAM\AppData\Local\Temp\arduino_build_143421/rec.ino.hex contains 3252 bytes
avrdude: reading on-chip flash data:Reading | #
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x00
##avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avr_read(): error reading address 0x0000avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00avrdude done. Thank you.
Sketch uses 3252 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 227 bytes (11%) of dynamic memory, leaving 1821 bytes for local variables. Maximum is 2048 bytes.
C:\Users\SHUBHAM\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\SHUBHAM\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\SHUBHAM\AppData\Local\Temp\arduino_build_143421/rec.ino.hex:iavrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "C:\Users\SHUBHAM\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" Using Port : COM3 Using Programmer : arduino Overriding Baud Rate : 115200 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : Arduino Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
the selected serial port
does not exist or your board is not connected
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
Hardware Version: 3
Firmware Version: 0.4611299avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
Vtarget : 420030.5 V
Varef : 197546963.2 V
Oscillator : 0.531 Hz
SCK period : 9207630.3 usavrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x00
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
option enabled in File -> Preferences.
i have tried loopback test. working good. updating all sorts of drivers and ide. Would appreciate any help
PS> Excuse me for my english
