hi there, i keep getting this error as i compiled the program. anyone know what should i do?
This is my code sketch :
#include <Mouse.h>
#include <HID.h>
const int xAxis = A1; //analog sensor for X axis
const int yAxis = A2; // analog sensor for Y axis
int range = 12; // output range of X or Y movement
int responseDelay = 2; // response delay of the mouse, in ms
int threshold = range/4; // resting threshold
int center = range/2; // resting position value
int minima = {
1023, 1023}; // actual analogRead minima for {x, y}
int maxima = {
0,0}; // actual analogRead maxima for {x, y}
int axis = {
xAxis, yAxis}; // pin numbers for {x, y}
int mouseReading[2]; // final mouse readings for {x, y}
Mouse.begin();
// read and scale the two axes:
int xReading = readAxis(0);
int yReading = readAxis(1);
// move the mouse:
Mouse.move(xReading, yReading, 0);
delay(responseDelay);
reads an axis (0 or 1 for x or y) and scales the
analog input range to a range from 0 to
int readAxis(int axisNumber) {
int distance = 0; // distance from center of the output range
// read the analog input:
int reading = analogRead(axis[axisNumber]);
// of the current reading exceeds the max or min for this axis,
// reset the max or min:
if (reading < minima[axisNumber]) {
minima[axisNumber] = reading;
if (reading > maxima[axisNumber]) {
maxima[axisNumber] = reading;
// map the reading from the analog input range to the output range:
reading = map(reading, minima[axisNumber], maxima[axisNumber], 0, range);
// if the output reading is outside from the
// rest position threshold, use it:
if (abs(reading - center) > threshold) {
distance = (reading - center);
// the Y axis needs to be inverted in order to
// map the movemment correctly:
if (axisNumber == 1) {
distance = -distance;
// return the distance for this axis:
return distance;
this error that i got :
Arduino: 1.8.1 (Windows 10), Board: “HoodLoader2 16u2, HoodLoader2 Uno”
Build options changed, rebuilding all
mouse:5: error: ‘A1’ was not declared in this scope
mouse:6: error: ‘A2’ was not declared in this scope
Multiple libraries were found for “Mouse.h”
Used: C:\Program Files (x86)\Arduino\libraries\Mouse
Not used: C:\Program Files (x86)\Arduino\libraries\HIDmaster
Multiple libraries were found for “HID.h”
Used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\HID
exit status 1
thanks…
