May be there is a better and easy way of going about this. I found this piece of code which is even more popular and efficient. It will at least not tie down my program like the other one. The only problem is that its sending only one sensor value to thingspeak whereas mine is sending three sensor values. please what will i have to change in the code to be able to send three sensor values rather than only one that the code was initially written to send. Thanks for your help
#include <SoftwareSerial.h>
//SIM800 TX is connected to Arduino D8
#define SIM800_TX_PIN 9
//SIM800 RX is connected to Arduino D7
#define SIM800_RX_PIN 10
//Create software serial object to communicate with SIM800
SoftwareSerial serialSIM800(SIM800_TX_PIN,SIM800_RX_PIN);
#define TIMEOUT 30000
int8_t answer;
int onModulePin = 13;
char aux_str[100];
int x = 0;
int attempts;
char apn[] = "internet.movistar.ve";
//char url[ ]="api.thingspeak.com/update?api_key=PHRFH37I50UK9MGF&field1=20.50";
char url[ ]="api.thingspeak.com/update?api_key=2TADWYFAJQJW76AN&field1=";
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 15000L; // delay between updates, in milliseconds
pinMode(onModulePin, OUTPUT);
//Begin serial comunication with Arduino and Arduino IDE (Serial Monitor)
while(!Serial);
//Being serial communication with Arduino and SIM800
serialSIM800.begin(9600);
Serial.println("Starting...");
power_on();
delay(3000);
//Serial.println("AT+HTTPPARA=\"URL\",\"www.castillolk.com.ve/WhiteList.txt\"\r\n");
while( (sendATcommand("AT+CREG?\r\n", "+CREG: 0,1\r\n", 500) ||
sendATcommand("AT+CREG?\r\n", "+CREG: 0,5\r\n", 500)) == 0 );
/* sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r\n", "OK\r\n", TIMEOUT);//sets Contype
snprintf(aux_str, sizeof(aux_str), "AT+SAPBR=3,1,\"APN\",\"%s\"\r\n", apn);//sets APN
sendATcommand(aux_str, "OK\r\n", TIMEOUT); */
connectToNetwork();
initHTTPSession();
HTTPRequest();
// if 15 seconds have passed since your last connection,
// then connect again and send data
if (millis() - lastConnectionTime > postingInterval) {
HTTPRequest();
int8_t sendATcommand(const char* ATcommand, const char* expected_answer1, unsigned int timeout) {
uint8_t x = 0, answer = 0;
char response[100];
unsigned long previous;
memset(response, '\0', 100); // Initialize the string
delay(100);
while (serialSIM800.available())
{ //Cleans the input buffer
serialSIM800.read();
Serial.println(ATcommand); // Prints the AT command
serialSIM800.write(ATcommand); // Sends the AT command
x = 0;
previous = millis();
// this loop waits for the answer
do
////if (Serial.available() != 0) {
if (serialSIM800.available() != 0)
////response[x] = Serial.read();
response[x] = serialSIM800.read();
x++;
// check if the desired answer is in the response of the module
if (strstr(response, expected_answer1) != NULL)
answer = 1;
// Waits for the asnwer with time out
while ((answer == 0) && ((millis() - previous) < timeout));
return answer;
void power_on()
uint8_t answer = 0;
Serial.println("On Power_on...");
// checks if the module is started
answer = sendATcommand("AT\r\n", "OK\r\n", TIMEOUT);
if (answer == 0)
// power on pulse
digitalWrite(onModulePin, HIGH);
delay(3000);
digitalWrite(onModulePin, LOW);
// waits for an answer from the module
while (answer == 0)
// Send AT every two seconds and wait for the answer
Serial.println("Trying connection with module...");
void restartPhoneActivity()
do
sendATcommand("AT+CFUN=0\r\n", "OK\r\n", TIMEOUT);
delay(2000);
answer = sendATcommand("AT+CFUN=1\r\n", "Call Ready\r\n", TIMEOUT);
}while(answer == 0);
void connectToNetwork()
attempts = 0;//tries 3 times or gets on the loop until sendATcommand != 0
while (sendATcommand("AT+SAPBR=1,1\r\n", "OK\r\n", TIMEOUT) == 0)
delay(5000);
attempts = attempts + 1;
if(attempts > 2)
restartPhoneActivity();
attempts = 0;
void initHTTPSession()
while (sendATcommand("AT+HTTPINIT\r\n", "OK\r\n", TIMEOUT) == 0)
connectToNetwork();
void HTTPRequest()
////snprintf(aux_str, sizeof(aux_str), "AT+HTTPPARA=\"URL\",\"%s\"\"%f\"\r\n", url, light);
float light = readLDR();
char sensorValue[6];
dtostrf(light,5,2,sensorValue);
snprintf(aux_str, sizeof(aux_str), "AT+HTTPPARA=\"URL\",\"%s\%s\"\r\n", url, sensorValue);
delay(3000);
while (sendATcommand("AT+HTTPACTION=0\r\n", "+HTTPACTION: 0,200,", TIMEOUT) == 0)
delay(5000);
if(attempts > 2)
sendATcommand("AT+SAPBR=0,1\r\n", "OK\r\n", 2 * TIMEOUT);
sendATcommand("AT+HTTPTERM\r\n", "OK\r\n", TIMEOUT);
connectToNetwork();
initHTTPSession();
////snprintf(aux_str, sizeof(aux_str), "AT+HTTPPARA=\"URL\",\"%s\"\r\n", url);
light = readLDR();
attempts = 0;
Serial.println("Successfully uploaded");
// note the time that the connection was made
lastConnectionTime = millis();
float readLDR()
//read the input on analog pin 0:
int sensorValue = analogRead(A0);
//Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
return voltage;
