Hello,
Total newbie here. Trying to upload to Arduino Nano (1.8.6) and getting the below error. Code is below that. Sorry if my code isn't formatted correctly. Thanks for any help!
Sketch uses 15218 bytes (49%) of program storage space. Maximum is 30720 bytes.
Global variables use 926 bytes (45%) of dynamic memory, leaving 1122 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe9
Failed uploading: uploading error: exit status 1
* Take Me Home
* A GPS-enabled portable "reverse geocache" puzzle that requires a portable puzzle
* to be taken to a specific real-world location. On arrival, a function is triggered
* that can, e.g. release a maglock, display a message etc.
// DEFINES
// When defined, prints additional debugging information to USB serial connection
#define DEBUG
// INCLUDES
// GPS sensor uses a (software) serial connection - this library is better than SoftwareSerial
#include "src/AltSoftSerial/AltSoftSerial.h"
// GPS library makes it easier to pass NMEA data sent from the GPS module
#include "src/TinyGPSPlus-1.0.2/TinyGPS++.h"
// Wire is a generic Arduino library for connection to any I2C devices
#include <Wire.h>
// LCD display library
#include "src/LiquidCrystal_PCF8574/LiquidCrystal_PCF8574.h"
// CONSTANTS
// Define the lat/long of the target location
// This can be found by going to Google Maps/Open Street Map, right-clicking a location and selecting "What's Here/Show Address"?
static const double targetLatitude = 52.22855, targetLongitude = 1.29832;
// Acceptable distance (in metres) from target that needs to be attained
const unsigned long targetProximity = 10;
// This pin will be (briefly) driven HIGH when the device is within proximity of the target location
const byte relayPin = 3;
// GLOBALS
// Initialise the LCD display with the specified I2C address.
// Common I2C addresses for a 16x2 character LCD screen are 0x27 and 0x3f
LiquidCrystal_PCF8574 lcd(0x3f);
// Instantiate the TinyGPS++ object
TinyGPSPlus gps;
// Create an emulated serial connection to the GPS device - AltSoftSerial uses pins RX 8, TX 9
AltSoftSerial SoftSerial;
#ifdef DEBUG
// Begin H/W serial connection to show debug info on the Arduino Serial Monitor
Serial.println(F("Entering setup"));
Serial.print(F("Initialising LCD..."));
#endif
lcd.begin(16, 2);
lcd.setBacklight(255);
delay(100);
lcd.home();
lcd.print("Take Me Home");
lcd.setCursor(0, 1);
lcd.print("v1.0");
delay(100);
#ifdef DEBUG
Serial.println(F("done!"));
Serial.print(F("Initialising GPS"));
#endif
// Begin S/W serial connection for GPS connection
SoftSerial.begin(9600);
delay(100);
#ifdef DEBUG
Serial.println(F("done"));
#endif
// Configure the output pin
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, LOW);
// If we have received a valid location from the GPS module
if (gps.location.isValid()) {
// Arduino printf doesn't support floating point values
// So use the dtostrf function to convert floating point numeric coordinates to char[8] strings
char latitude[8];
char longitude[8];
// Convert coordinates to width of 7, with 4 d.p.
dtostrf(gps.location.lat(), 7, 4, latitude);
dtostrf(gps.location.lng(), 7, 4, longitude);
// Build up a string representation of the location
char line[16];
memset(line, 0, sizeof line);
snprintf(line, 16, "%s%s", latitude, longitude);
// Clear the LCD display
lcd.clear();
lcd.home();
// Write the location to the top line
lcd.print(line);
// And, if debugging enabled, write to the serial output too
#ifdef DEBUG
Serial.println(line);
#endif
// Calculate the distance to the target location
unsigned long distToTarget = (unsigned long)TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
targetLatitude,
targetLongitude);
// Write the distance to the line var
snprintf(line, 16, "%ldm to go", distToTarget);
// Write the distance to the second line
lcd.print(line);
#ifdef DEBUG
#endif
// This is the section of code which executes if we're within proximity
// of the target
if (distToTarget < targetProximity) {
// Write a message to the display
lcd.clear();
lcd.home();
lcd.print("CONGRATULATIONS");
lcd.print("Treasure found!");
// Or, play a sound
tone(4, 440, 1000);
// Or, release a maglock
digitalWrite(relayPin, HIGH);
nonBlockingDelay(100);
// And wait a bit for continuing
nonBlockingDelay(2000);
// This is the section of code if we cannot obtain a valid location
else {
lcd.clear();
lcd.home();
// Build up a string for the display
char line[16] = "Where am I?";
lcd.print(line);
// Move to the next line
// Clear the character array
// Create a line of increasing dots
static int n = 0;
for (int i = 0; i < n; i++) {
line[i] = '.';
n++;
// If we reach the end of the the line, start again
if (n > 15) { n = 0; }
// Draw the dots on the second line of the display
lcd.print(line);
// We don't use a regular "delay()" as we don't want to miss incoming GPS data
nonBlockingDelay(1000);
#ifdef DEBUG
// If we've not received any data in the last 5 seconds
if (millis() > 5000 && gps.charsProcessed() < 10) {
Serial.println(F("No GPS data received: check wiring"));
#endif
// Calling this function instead of normal delay() ensures that incoming data from the GPS module
// is still read even while the rest of code execution is paused
static void nonBlockingDelay(unsigned long ms) {
unsigned long start = millis();
do {
while (SoftSerial.available()) {
gps.encode(SoftSerial.read());
} while (millis() - start < ms);
