Hello!
I'm working with my ESP8266 (ESP-12e) wifi module for my Arduino Uno.
I programmed it with this:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
String apiKey = "KBD1JSZTUKCXJ15V"; // Enter your Write API key from ThingSpeak
const char *ssid = "Alexahome"; // replace with your wifi ssid and wpa2 key
const char pass = "loranthus";
const char server = "api.thingspeak.com";
#define LED_BUILTIN 16
#define SENSOR 2
long currentMillis = 0;
long previousMillis = 0;
int interval = 1000;
boolean ledState = LOW;
float calibrationFactor = 4.5;
volatile byte pulseCount;
byte pulse1Sec = 0;
float flowRate;
unsigned long flowMilliLitres;
unsigned int totalMilliLitres;
float flowLitres;
float totalLitres;
void IRAM_ATTR pulseCounter()
pulseCount++;
WiFiClient client;
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
display.clearDisplay();
delay(10);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(SENSOR, INPUT_PULLUP);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
previousMillis = 0;
attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, FALLING);
currentMillis = millis();
if (currentMillis - previousMillis > interval)
pulse1Sec = pulseCount;
pulseCount = 0;
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
previousMillis = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
flowLitres = (flowRate / 60);
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
totalLitres += flowLitres;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(float(flowRate)); // Print the integer part of the variable
Serial.print("L/min");
Serial.print("\t"); // Print tab space
display.setCursor(10,0); //oled display
display.setTextSize(1);
display.setTextColor(WHITE);
display.print("Water Flow Meter");
display.setCursor(0,20); //oled display
display.setTextSize(2);
display.print("R:");
display.print(float(flowRate));
display.setCursor(100,28); //oled display
display.print("L/M");
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.print("mL / ");
Serial.print(totalLitres);
Serial.println("L");
display.setCursor(0,45); //oled display
display.print("V:");
display.print(totalLitres);
display.setCursor(100,53); //oled display
display.print("L");
display.display();
if (client.connect(server, 80)) // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr += "&field1=";
postStr += String(float(flowRate));
postStr += "&field2=";
postStr += String(totalLitres);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
client.stop();
This is my error code:
arduino:1.8.15 (Windows 10), 보드:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible),
32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 258924 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28309 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1516 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1252 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 26624 ) - zeroed variables (global, static) in RAM/HEAP
스케치는 프로그램 저장 공간 290001 바이트(27%)를 사용. 최대 1044464 바이트.
전역 변수는 동적 메모리 29392바이트(35%)를 사용, 52528바이트의 지역변수가 남음. 최대는 81920 바이트.
esptool.py v3.0
Serial port COM4
Connecting......................................____Traceback (most recent call last):
File "C:\Users\alsrb\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0/tools/upload.py", line 66, in
esptool.main(cmdline)
File "C:/Users/alsrb/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "C:/Users/alsrb/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 529, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
selected signal port_
doesn't exist or the board is not connected
During the compiling it doesn't make an issue. But whenever I'm trying to send it to the Board, it makes the problem .
I can see the board is connected to COM4 on tool\serialport and I can see on . Device Manager\USB Serial Port (COM4)
PLZ help me...
