Uploading error on Arduino Leonordo - Programmer not responding maybe bootloader
Green LED is on. Yellow LED (L) was blinking when updalod worked. Now it is off.Bootloader
• Make sure there's a bootloader burned on your Arduino board. To check, reset the board. The built-in L LED (which is connected to pin 13) should blink. If it doesn't, there may not be a bootloader on your board.
If it still doesn't work, you can ask for help in the forum. Please include the following information:
• Your operating system.
• What kind of board you have. If it's a Mini, LilyPad or other board that requires extra wiring, include a photo of your circuit, if possible.
• Whether or not you were ever able to upload to the board. If so, what were you doing with the board before / when it stopped working, and what software have you recently added or removed from your computer?
• The messages displayed when you try to upload with verbose output enabled. To do this, hold down the shift key while clicking on the upload button in the toolbar.
  1. OS : Mac OS X 10.6.8
  2. Arduino Leonardo
  3. Upload was working before and tried few sketches (e.g. blink) and were working.
  4. Tried FTFIU.. driver for serial port. Found out it is not needed on Mac. Deleted driver from the system files and rebooted Mac.
  5. This is what I get when uploading now.
PORTS {/dev/tty.Bluetooth-PDA-Sync, /dev/cu.Bluetooth-PDA-Sync, /dev/tty.Bluetooth-Modem, /dev/cu.Bluetooth-Modem, } / {/dev/tty.Bluetooth-PDA-Sync, /dev/cu.Bluetooth-PDA-Sync, /dev/tty.Bluetooth-Modem, /dev/cu.Bluetooth-Modem, } => {}
Uploading using selected port: /dev/tty.Bluetooth-PDA-Sync
/Users/vasant910/Arduino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/vasant910/Arduino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/tty.Bluetooth-PDA-Sync -b57600 -D -Uflash:w:/var/folders/7g/7gguPxHjGWyCTwbux+O6e++++TI/-Tmp-/build3772158437656005330.tmp/BareMinimum.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/vasant910/Arduino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/vasant910/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.Bluetooth-PDA-Sync
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding
After reconnecting USB cable, upload start working. So it was a bad connection. If you see this problem, it may be a USB cable.
