I want to upload my code but it is showing "Sketch uses 2826 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 243 bytes (11%) of dynamic memory, leaving 1805 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xde
Failed uploading: uploading error: exit status 1"
The Code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
char inbyte; //Setting a char variable as inbyte
int LED = 13; //LED on pin 13
void setup(){
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// initialize the serial communications:
digitalWrite(LED, LOW);
// initialize the LED pin as an output
pinMode(LED, OUTPUT);
// When a character arrives on the serial port this will be true
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
//store the first character in var inbyte
inbyte = Serial.read();
if( inbyte == '1' ) function1(); //if the byte is an ASCII 0 execute function 1
if( inbyte == '2' ) function2(); //if the byte is an ASCII 9 execute function 2
//if it is * then we know to expect text input from Android
if (inbyte == '*')
//clear lcd screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0)
// display each character to the LCD
lcd.write(Serial.read());
void function1()
//Enter what you want the command to initiate (e.g LED, Servo etc)
digitalWrite(LED, HIGH);
lcd.clear();
lcd.write("Function 1");
void function2()
lcd.clear();
lcd.write("Function 2");
