In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/CatmullRom.cpp:1:0:
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/CatmullRom.h:9:24: error: 'constexpr' needed for in-class initialization of static data member 'const float CatmullRom::END_STEP_SIZE' of non-integral type [-fpermissive]
static const float END_STEP_SIZE = 1;
In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.h:6:0,
from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.h:9,
from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.cpp:1:
In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.h:9:0,
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.h:13:24: error: 'constexpr' needed for in-class initialization of static data member 'const float PurePursuit::DEFAULT_INTERPOLATION_STEP' of non-integral type [-fpermissive]
static const float DEFAULT_INTERPOLATION_STEP = 20; // mm
In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.h:10:0,
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/DeadReckoner.h:12:21: error: 'constexpr' needed for in-class initialization of static data member 'const float DeadReckoner::RAD_PER_SEC_TO_RPM' of non-integral type [-fpermissive]
static const float RAD_PER_SEC_TO_RPM = 30.0 / PI;
In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.cpp:1:0:
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.h:68:21: error: 'constexpr' needed for in-class initialization of static data member 'const float PreMo::_END_STEP_ANGLE' of non-integral type [-fpermissive]
static const float _END_STEP_ANGLE = 0.001 * PI/180; // rad
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.h:84:21: error: 'constexpr' needed for in-class initialization of static data member 'const float PreMo::_TWIST_THRESHOLD_ANGLE' of non-integral type [-fpermissive]
static const float _TWIST_THRESHOLD_ANGLE = 2;
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.cpp:134:63: error: default argument given for parameter 2 of 'void PreMo::twist(float, int)' [-fpermissive]
void PreMo::twist(float targetHeading, int direction=TWIST_MIN)
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PreMo.h:32:7: note: previous specification in 'void PreMo::twist(float, int)' here
void twist(float targetHeading, int twist=TWIST_MIN);
In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/DeadReckoner.cpp:1:0:
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/DeadReckoner.cpp:7:56: error: default argument given for parameter 6 of 'DeadReckoner::DeadReckoner(volatile long unsigned int*, volatile long unsigned int*, int, double, double, long unsigned int)' [-fpermissive]
int tpr, double r, double l, unsigned long ci=50) {
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/DeadReckoner.h:14:2: note: previous specification in 'DeadReckoner::DeadReckoner(volatile long unsigned int*, volatile long unsigned int*, int, double, double, long unsigned int)' here
DeadReckoner(volatile unsigned long *left, volatile unsigned long *right,
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/DeadReckoner.cpp:12:56: error: default argument given for parameter 6 of 'void DeadReckoner::Init(volatile long unsigned int*, volatile long unsigned int*, int, double, double, long unsigned int)' [-fpermissive]
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/DeadReckoner.h:16:7: note: previous specification in 'void DeadReckoner::Init(volatile long unsigned int*, volatile long unsigned int*, int, double, double, long unsigned int)' here
void Init(volatile unsigned long *left, volatile unsigned long *right,
from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.cpp:2:
In file included from /var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.cpp:2:0:
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.cpp:6:133: error: default argument given for parameter 5 of 'PurePursuit::PurePursuit(double*, double*, double*, double, long unsigned int, int)' [-fpermissive]
PurePursuit::PurePursuit(double* xPos, double* yPos, double *heading, double LOOK_AHEAD, unsigned long INTERVAL=50, int STOP_POINT=3)
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.h:14:5: note: previous specification in 'PurePursuit::PurePursuit(double*, double*, double*, double, long unsigned int, int)' here
PurePursuit(double* xPos, double* yPos, double *heading, double LOOK_AHEAD, unsigned long INTERVAL=50, int STOP_POINT=3);
/var/run/arduino/directories-user/libraries/PreMo_-_Virtual_Path_Following/src/PurePursuit.cpp:6:133: error: default argument given for parameter 6 of 'PurePursuit::PurePursuit(double*, double*, double*, double, long unsigned int, int)' [-fpermissive]
Multiple libraries were found for "NTPClient.h"
Used: /run/arduino/directories-data/internal/NTPClient_3.2.1_2a5cb6396268ddb9
Not used: /run/arduino/directories-data/internal/ESP8266_Weather_Station_2.3.0_87d62dd775e2e673
Not used: /run/arduino/directories-data/internal/microgear-nbiot_0.8.0_c5678e6ebc44457c
Not used: /run/arduino/directories-data/internal/iSYNC_BC95_Arduino_0.8.4_18489cf4800aee8a
Multiple libraries were found for "Wire.h"
Used: /run/arduino/directories-data/packages/arduino/hardware/mbed_opta/4.2.1/libraries/Wire
Not used: /run/arduino/directories-data/internal/FlexWire_1.2.1_1fc5f1d1a14af0e7
Multiple libraries were found for "Ethernet.h"
Used: /run/arduino/directories-data/packages/arduino/hardware/mbed_opta/4.2.1/libraries/Ethernet
Not used: /run/arduino/directories-data/internal/UIPEthernet_2.0.12_26ab7606efa7faff
Not used: /run/arduino/directories-data/internal/EthernetENC_2.0.5_93a44d241bd7af31
Not used: /run/arduino/directories-data/internal/EthernetEspAT_1.0.0_694dc7e653834070
Not used: /run/arduino/directories-data/internal/EventEthernet_1.0.0_bd9dd894ef7641f8
Not used: /run/arduino/directories-data/internal/EthernetESP32_1.0.2_5fcee5bc10aab871
Not used: /run/arduino/directories-data/internal/EthernetSP_1.0.1_fc08252e297d31cf
Not used: /run/arduino/directories-data/internal/Ethernet_2.0.2_42177577e1867cbe
Multiple libraries were found for "WiFi.h"
Used: /run/arduino/directories-data/packages/arduino/hardware/mbed_opta/4.2.1/libraries/WiFi
Not used: /run/arduino/directories-data/internal/VEGA_WiFiNINA_1.0.1_ab2db6059607e9f4
Not used: /run/arduino/directories-data/internal/WiFi_1.2.7_c357666d3257ae8a
Not used: /run/arduino/directories-data/internal/NINA-Wi-Fi_1.0.1_8b5f9e1dc71eca55
Not used: /run/arduino/directories-data/internal/WiFiEspAT_1.5.0_5169a7bcde168205
Not used: /run/arduino/directories-data/internal/Seeed_Arduino_rpcWiFi_1.1.0_a93a349668c69c81
Not used: /run/arduino/directories-data/internal/BetterWiFiNINA_1.3.0_0ccca45bdf408f34
Not used: /run/arduino/directories-data/internal/indhilib_3.0.5_645ae16078e566f4
Not used: /run/arduino/directories-data/internal/WiFiNINA_1.8.14_50fd037d6f2f4b4b
Not used: /run/arduino/directories-data/internal/DA16200_Wi-Fi_Library_for_Arduino_1.1.0_9d156d307009fe30
Multiple libraries were found for "ECCX08.h"
Used: /run/arduino/directories-data/internal/ArduinoECCX08_1.3.8_fb8ab5b39cf9f121
Not used: /run/arduino/directories-data/internal/RAK5814-ATECC608A_1.0.0_3080811c7019c906
Multiple libraries were found for "TimeLib.h"
Used: /run/arduino/directories-data/internal/Time_1.6.1_523097fa64b6a5aa
Not used: /run/arduino/directories-data/internal/DFRobot_OLED12864_1.0.0_84b506fbe1776923
Not used: /run/arduino/directories-data/internal/ESP32_Control_1.2.8_5f3f3e5eab0e7f01
Multiple libraries were found for "PID_v1.h"
Used: /run/arduino/directories-data/internal/PreMo_-_Virtual_Path_Following_2.0.0_748c97c0b66f5671
Not used: /run/arduino/directories-data/internal/PID_1.2.0_102209116b6b8db6
this is the error i get when im uploading same sketch that i uploaded successfully few days ago to my OPTA .
uploading through arduino IDE works , but with the cloud it refers me to some "PreMo_-_Virtual_Path_Following" library which im not using .
