I have an Arduino Uno and a program of mine which worked 2 years ago. I've resurrected it but when I attempt to download, usiing the verbose option here's what I get. I'm on a Mac.
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31
System wide configuration file is "/Users/billmeng/Desktop/Programs/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/billmeng/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem0000121D1
Using Programmer : stk500v1
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: Send: Q [51] [20]
The systemwide config file is missing, which may be the problem. If so how can I reconfigure it other than deleting all of the Arduino programs and re-installing all.
I have been unable to find the configuration files,
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
Cpat:
Ignore this error.
If the Receive light blinks and the Transmit light doesn't then your bootloader is not responding. Did you ever swap out the processor? Did you ever upload a sketch via ICSP? Did you ever burn an alternative bootloader via ICSP?
Sounds like it is time to burn a fresh bootloader. Do you have an ISP device or a working UNO to use as an ISP?
