uploading error
i am constantly facing these errors.
someone please help.
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
:\Users\CHP PC\DEVANSH\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\HP PC\DEVANSH\hardware\arduino\avr\cores\arduino -IC:\Users\HP PC\DEVANSH\hardware\arduino\avr\variants\standard C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\Blink.cpp -o C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\Blink.cpp.o
C:\Users\HP PC\DEVANSH\hardware\tools\avr/bin/avr-gcc -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\HP PC\DEVANSH\hardware\arduino\avr\cores\arduino -IC:\Users\HP PC\DEVANSH\hardware\arduino\avr\variants\standard C:\Users\HP PC\DEVANSH\hardware\arduino\avr\cores\arduino\wiring_pulse.S -o C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\wiring_pulse.S.o
Using previously compiled file: C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\hooks.c.o
Using previously compiled file: C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\WInterrupts.c.o
Using previously compiled file: C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\wiring.c.o
Using previously compiled file: C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\wiring_analog.c.o
Using previously compiled file: C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp\wiring_digital.c.o
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Users\HP PC\DEVANSH\hardware\tools\avr/bin/avrdude -CC:\Users\HP PC\DEVANSH\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp/Blink.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\HP PC\DEVANSH\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.68
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x50
Vtarget : 0.3 V
Varef : 268591.6 V
Oscillator : 921.600 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\HPPC~1\AppData\Local\Temp\build4058384835903545187.tmp/Blink.cpp.hex"
avrdude: writing flash (1030 bytes):
Writing | ################avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x54
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x10
######avrdude: stk500_recv(): programmer is not responding
