uploading error
i have recently bought a arduino uno R3 with the arduino diy starter pack and i instaled the arduino coding progrem and everything was fine until i needed to upload my scetch it gave an error and a link i have tried a lot of things from that website but it didn't work could someone please help me.
with thanks
-Me
Ps: I'm running windows
I can see nothing wrong with the code that you have not posted, nor does the error message that you have not posted provide any clues as to what might be wrong.
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
sorry here is the error and the code (it was just a first test)
sketch_dec20a.ino (139 Bytes)
i cant give the full error
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM256
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x16
avrdude done. Thank you.
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#upload voor suggesties.
So, why didn't you?
You forgot to use code tags as I asked. And don't post your sketch as an attachment when it's short enough to put directly in the post (also using code tags.
tuxiben:
Using Port : COM256
Is your board really on COM256? That's the highest COM port number I've ever seen.
