I also have a brand new UNO i purchased last week that I cannot upload any sketch to.
Yes, I read through the guides and tried swapping cables (I am using the same cable that sucessfully programs a Mega 2560), updated to newest version that I could find (arduino 1.0), changed drivers, etc.
When I do the loopback test I enter "testtesttest" and it responds with
"testt" and nothing further on any subsequent entries to it.
I have to do a power down cycle for it to respond again.
When I try to upload blink this is what it says:
Binary sketch size: 1026 bytes (of a 32256 byte maximum)
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x42
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
When I press shift upload:
avrdude: usbdev_open(): did not find any USB device "usb"
I can see the arduino listed in windows' device mangler com ports as com 11. It also will go away when unplugged and return working properly when plugged back in.
If I use arduino ver 00.22 and it's UNO driver, with a shift upload then this is what it prints:
Binary sketch size: 1018 bytes (of a 32256 byte maximum)
D:\arduino\arduino-0022\hardware/tools/avr/bin/avrdude -CD:\arduino\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\.\COM11 -b115200 -D -Uflash:w:C:\DOCUME~1\STUDYC~1\LOCALS~1\Temp\build4371714467456052767.tmp\Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
System wide configuration file is "D:\arduino\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM11
Using Programmer : stk500v1
Overriding Baud Rate : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: Recv:
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x86
avrdude: Send: A [41] . [81] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x18
avrdude: Send: A [41] . [82] [20]
avrdude: Recv:
avrdude: Send: A [41] . [98] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
Hardware Version: 4174060
Firmware Version: 4417552.4368076
avrdude: Send: A [41] . [84] [20]
avrdude: Recv:
avrdude: Send: A [41] . [85] [20]
avrdude: Recv:
avrdude: Send: A [41] . [86] [20]
avrdude: Recv:
avrdude: Send: A [41] . [87] [20]
avrdude: Recv:
avrdude: Send: A [41] . [89] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x1e
Vtarget : 201333138.4 V
Varef : 229372.8 V
Oscillator : 0.002 Hz
SCK period : 2184798758.7 us
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x66
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x60
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Recv:
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x06
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude done. Thank you.
