Hello Forum (for the first time),
I am trying to do something very simple but have run into a problem that I cannot figure out. I have adapted Ovidiu Predescu’s TinyWebServer to build a internet-based door opener for our chicken coop. Everything works great and it is ready to be installed.
I also want to be able to measure the temperature inside the coop and report it when I make an http request. I’ve added a DS18B20 sensor on digital pin 8 and run the sample sketch provided with the OneWire library and it runs fine.
The problem comes when I combine the two sketches I get the following message:
Problem uploading to board.
Binary sketch size: 31320 bytes (of a 32256 byte maximum)
I thought it was a size issue because I have read here on the forums that the actual maximum is lower than 32256 but I have made the sketch smaller (by taking out the file upload routine from TinyWebServer) and had the same issue. The code below is a version that has the OneWire code integrated into the temp_handler routine but I have also written it using a separate routine that returns a float. That version fails only when I call the OneWire routine from within the temp_handler.
Anyone have any ideas? It is getting to be well below -18 C here at night and I am tired of manually running out to close the coop door so I would like to get this thing installed soon!
You help will be much appreciated.
-Micah
p.s.- My code was longer that 9500 characters so I deleted the routines that were unchanged (or only minor changes ) from Ovidiu’s blink_led sketch.
// Chicken Coop 2.1
#include <SPI.h>
#include <Ethernet.h>
#include <Flash.h>
#include <SD.h>
#include <TinyWebServer.h>
#include <OneWire.h>
//Temperature chip i/o
OneWire ds(8); // on digital pin 8
// The LED attached in PIN 13 on an Arduino board.
const int ledPin = 7;
const int motor1Pin = 5; // H-bridge leg 1 (pin 2, 1A)
const int motor2Pin = 6; // H-bridge leg 2 (pin 7, 2A)
const int enablePin = 9; // H-bridge enable pin
void activateMotor(boolean state) {
ledState = state;
// set enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// Go up if ledState is low, go down of LED state is High
if (ledState == 0) {
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge high
delay(4800);
Serial.println("DONE-1");
// if the switch is low, motor will turn in the other direction:
else {
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge low
delay(4200);
Serial.println("DONE-2");
// turn off the H-Bridge to stop the motor
digitalWrite(enablePin, LOW);
Serial.println("DONE-3");
inline boolean getLedState() { return ledState; }
boolean file_handler(TinyWebServer& web_server);
boolean blink_led_handler(TinyWebServer& web_server);
boolean led_status_handler(TinyWebServer& web_server);
boolean index_handler(TinyWebServer& web_server);
boolean temp_handler(TinyWebServer& web_server);
TinyWebServer::PathHandler handlers[] = {
// Micah put in the 'temp_handler'
{"/", TinyWebServer::GET, &index_handler },
{"/upload/" "*", TinyWebServer::PUT, &TinyWebPutHandler::put_handler },
{"/blinkled", TinyWebServer::POST, &blink_led_handler },
{"/temp", TinyWebServer::GET, &temp_handler },
{"/ledstatus" "*", TinyWebServer::GET, &led_status_handler },
{"/" "*", TinyWebServer::GET, &file_handler },
{NULL},
// TEMP HANDLER - Micah
boolean temp_handler(TinyWebServer& web_server) {
web_server.send_error_code(200);
web_server.end_headers();
// Minimal Temp stuff from OneWire example
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return false;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return false;
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
default:
Serial.println("Device is not a DS18x20 family device.");
return false;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// convert the data to actual temperature
unsigned int raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// count remain gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
web_server << F("<html><body><h1>Hello Micah, the Temperature is </h1></body></html>\n");
return true;
