Uploading errors using windows xp
I have my desktop running windows 8 and have no problems uploading from it. I am trying to use my dads old laptop running windows xp for uploading and keep getting errors. One issue I run into is the IDE frequently cannot find the serial port, only COM1 and COM3 are shown. When it does find COM5 or 6 it only sometimes works. It uploaded blink fine, then I uploaded the same copy of code already on my uno and it said that uploaded fine (didn’t change anything so I am not sure if the upload worked or if it simply restarted it). Then I tried to change a few values to see a difference and keep getting this error:
Binary sketch size: 12,986 bytes (of a 32,256 byte maximum)
processing.app.SerialException: Serial port 'COM5' already in use. Try quiting any programs that may be using it.
	at processing.app.Serial.<init>(Serial.java:171)
	at processing.app.Serial.<init>(Serial.java:77)
	at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
	at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
	at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
	at processing.app.Sketch.upload(Sketch.java:1671)
	at processing.app.Sketch.exportApplet(Sketch.java:1627)
	at processing.app.Sketch.exportApplet(Sketch.java:1599)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
	at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Serial port 'COM5' already in use. Try quiting any programs that may be using it.
	at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
I did not disconnect the uno in between uploads, I just changed some numbers in the sketch. Here is the code:
#include <Adafruit_PWMServoDriver.h>
#include <Wire.h>
#include "RTClib.h"
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
#include "DHT.h" //DHT library
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
int r = 500;
int b = 500;
int c = 1;
int w = 1;
int rstep = 1;
int bstep = 1;
int cstep = 1;
int wstep = 1;
int rday = 2000;
int bday = 1000;
int cday = 3000;
int wday = 4095;
int rnight = 10;
int bnight = 500;
int cnight = 0;
int wnight = 0;
DHT dht1; // define dht1 as a DHT
DHT dht2; // define dht2 as a DHT
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
int button = 1; //variable for buttons
int rain = 0;
RTC_DS1307 rtc;
  Serial.begin(57600);
#ifdef AVR
  Wire.begin();
#else
  Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
  rtc.begin();
  lcd.begin(16, 2);
  lcd.setBacklight(GREEN);
  dht1.setup(7); // assign dht1 to pin 2
  dht2.setup(8); // assign dht2 to pin 4
 //outlet control
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  digitalWrite(2, HIGH);
  digitalWrite(3, LOW); //pump on
  digitalWrite(4, HIGH);
  digitalWrite(5, HIGH);
  pwm.begin();
  pwm.setPWMFreq(1600);  // This is the maximum PWM frequency
  // save I2C bitrate
  uint8_t twbrbackup = TWBR;
  // must be changed after calling Wire.begin() (inside pwm.begin())
  TWBR = 12; // upgrade to 400KHz!
uint8_t i=0;
  DateTime now = rtc.now();
  dht1.getMinimumSamplingPeriod();
  float humidity = dht1.getHumidity();
  float temperature = dht1.getTemperature();
  //setup dht1
  dht2.getMinimumSamplingPeriod();
  float humidity2 = dht2.getHumidity();
  float temperature2 = dht2.getTemperature();
  //setup dht2
  uint8_t buttons = lcd.readButtons();
  // LED no longer fading, switch direction
  if (now.hour() >= 8 && now.hour() < 9) {
    pwm.setPWM(3, 0, c);
    if (c < cday) {
      c = c + cstep;
    pwm.setPWM(0, 0, w);
    if (w < wday) {
      w = w + wstep;
    pwm.setPWM(1, 0, b);
    if (b < bday) {
      b = b + bstep;
    pwm.setPWM(2, 0, r);
    if (r < rday) {
      r = r + rstep;
   if (now.hour() >= 9 && now.hour() < 21) {
    if (c < cday) {
      c = c + cstep;
    if (w < wday) {
      w = w + wstep;
    if (b < bday) {
      b = b + bstep;
    if (r < rday) {
      r = r + rstep;
    delay(5);
      digitalWrite(2, LOW);
   if (now.hour() >= 21 && now.hour() < 22) {
    if (c > cnight) {
      c = c - cstep;
    if (w > wnight) {
      w = w - wstep;
    if (b > bnight) {
      b = b - bstep;
    if (r > rnight) {
      r = r - rstep;
   if (now.hour() >= 22 || now.hour() < 8) {
    if (c > cnight) {
      c = c - cstep;
    if (w > wnight) {
      w = w - wstep;
    if (b > bnight) {
      b = b - bstep;
    if (r > rnight) {
      r = r - rstep;
  //turn on outlet 1 if humidity drops below 60%
   if ((humidity + humidity2)/2 <= 70) {
     digitalWrite(5, LOW);
   if ((humidity + humidity2)/2 >= 85) {
   //rain times
   if (now.hour() == 4 && now.minute() == 20 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 4 && now.minute() == 20 && now.second() == 12) {
     rain = 0;
   if (now.hour() == 7 && now.minute() == 24 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 7 && now.minute() == 24 && now.second() == 15) {
     rain = 0;
   if (now.hour() == 11 && now.minute() == 24 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 11 && now.minute() == 24 && now.second() == 8) {
     rain = 0;
   if (now.hour() == 14 && now.minute() == 24 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 14 && now.minute() == 24 && now.second() == 15) {
     rain = 0;
   if (now.hour() == 17 && now.minute() == 24 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 17 && now.minute() == 24 && now.second() == 10) {
     rain = 0;
   if (now.hour() == 20 && now.minute() == 24 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 20 && now.minute() == 24 && now.second() == 10) {
     rain = 0;
   if (now.hour() == 23 && now.minute() == 24 && now.second() == 0) {
     rain = 1;
   if (now.hour() == 23 && now.minute() == 24 && now.second() == 10) {
     rain = 0;
   //turn on rain if it is rain time
   if (rain == 0 && (humidity + humidity2)/2 >= 85) {
   if (rain == 1) {
   if (buttons) {
    lcd.clear();
    lcd.setCursor(0,0);
      if (buttons & BUTTON_UP) {
      button = 1;
      if (buttons & BUTTON_DOWN) {
      button = 2;
      if (buttons & BUTTON_LEFT) {
      button = 3;
  if (button == 1) {
    lcd.setCursor(0,0);
    lcd.print("Temp  #1 ");
    lcd.print(dht1.toFahrenheit(temperature), 1);
    lcd.setCursor(0,1);
    lcd.print("Humidity #1 ");
    lcd.print(humidity, 1);
  } // if up button is pushed show dht1 results
  if (button == 2) {
    lcd.setCursor(0,0);
    lcd.print("Temp  #2 ");
    lcd.print(dht2.toFahrenheit(temperature2), 1);
    lcd.setCursor(0,1);
    lcd.print("Humidity #2 ");
    lcd.print(humidity2, 1);
  } // if down button is pushed show dht2 results
  if (button == 3) {
    lcd.setCursor(0, 0);
    lcd.print(now.year(), DEC);
    lcd.print('/');
    lcd.print(now.month(), DEC);
    lcd.print('/');
    lcd.print(now.day(), DEC);
    lcd.setCursor(0, 1);
    lcd.print(now.hour(), DEC);
    lcd.print(':');
    lcd.print(now.minute(), DEC);
  } // if if left button is pushed show time
This code works 100% of the time when using my desktop running windows 8.
Save your changes and restart XP.
In the past XP had some issues with USB serial ports. Each time a USB serial port was plugged in, a newer higher number com port was formed for the adapter. check in device manager to see if you have a number of serial ports showing.
edit: with the arduino plugged in to the usb port, check to see if the arduino has been assigned a different port number.
I tried to restart the computer and received the following error again:
In the device manager the COM port for the Uno is COM5 which is the selected COM port in the IDE. Also when I disconnect the arduino and plug it back into the computer the device manager still shows that it is under COM5
If you know nothing is currently using com 5, you might go to device manager> serial port > properties > port settings > advanced for the arduino com port and ensure com 5 is assigned to the arduino.
In the advanced section of the arduino COM port it is COM5
After you reboot your computer do you then get the com 5 issue when the serial monitor is opened? If so, you can go into the arduino com port advanced properties and change the comport being used from com5 to another port like com6 and see if com6 can be used by the IDE.
I got the same problem when the serial monitor was open. When I changed the arduino COM port the IDE cannot find it. I have it on COM 7 and the IDE only finds COM 1 and 3.
After restarting the computer again the IDE found COM 7, but again got the following error:
processing.app.SerialException: Serial port 'COM7' already in use. Try quiting any programs that may be using it.
processing.app.debug.RunnerException: Serial port 'COM7' already in use. Try quiting any programs that may be using it.
Are the appropriate serial port drivers installed for the arduino you are using?
I tried to update the driver and windows said it could not find a newer version. It says the driver version is 1.0.0.0 with a driver date:1/1/2013
The uno requires a driver not normally installed by default in windows. The uno serial driver arduino.inf is located in the arduino drivers folder.
In the driver folder for arduino there is a arduino.inf file. Not sure how to check if it is the correct version. There is also a zip file for old drivers which has one for arduino uno rev3 and one for arduino uno. Should I try to replace the arduino.inf with the Arduino Uno.inf?
Switching drivers to the old ones did not work.
