Uploading Failure: not in sync
Hello,
I was trying to upload the Blink example:
// the setup function runs once when you press reset or power the board
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
but it gives me the 'not in sync' error.
Error message:
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Users\cpel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\cpel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\cpel\AppData\Local\Temp\builda07ce906557dd04317cc33717fe047ca.tmp/_1_LED_blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\cpel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa3
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I followed the instructions on https://www.arduino.cc/en/Guide/Troubleshooting#upload and it still gives the error message.
I've updated the board and libraries.
I am using the Arduino 1.6.8 program on Windows 10 and the board is Arduino Uno.
The correct COM and board are selected.
I've also tried the Loop-Back Test and changing the USB 2.0 cables.
This is the first time I've used the board.
Any help will be greatly appreciated.
Does the Arduino Uno show up in Device Manager?
What was the result of the loopback test?
