Uploading file error
I just got an arduino (i already worked with them but i wanted to buy one) but it crashes if i want to upload a file... Here's the error:
Arduino: 1.6.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
  • This report would have more information with*
  • "Show verbose output during compilation"*
  • enabled in File > Preferences.*
I hope one of you can help me,
Thijs
Looks like:
  • or you did not select the right COM port from Tools -> Port
  • or you did not select the right board from tools -> Board
  • or you did not install the driver for the Arduino. Goto device manager and look under Ports. No ! there?
If i go to the manager, i see COM2 as an communication port, so i think that the port isn´t the problem. I´ll check the other things.
I chose COM2 and selected the Arduino/Genuino Uno...
Tried it again, an error again:
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf9
TheTvL:
And is COM2 gone if you unplug the Uno?
Hello,
I'm bumping this problem up! Got the same message Error.
1 - I have selected the rigth board
2 - I have selected the rigth Serial / com
3 - I have re-install everything (Driver & IDE)
4 - Other board (YUN) was running perfectly last week on the same machine
5 - I can't reset the board (tried 2-5 sec hold and 32-37 sec hold)
6 - Interesting fact the LED 13 on the board is constantly on
Thank you for helping, i'm a new user and can't wait to get started.
Regards,
Error: Arduino: 1.6.7 (Windows 10), Board: "Arduino/Genuino Uno"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x59
