When first talking to Mini Pro everything works. First sketch uploads and runs. BUT subsequent upload attempts error out.
Have tried on two different Mini Pros. Same results.
Running on Ubuntu. Port /dev/ttyUSB0 OK - seen and permissions are correct.
Error message:
Arduino: 1.6.12 (Linux), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
/data/arduino/arduino-1.6.12/hardware/tools/avr/bin/avrdude -C/data/arduino/arduino-1.6.12/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_876010/pin-blink.ino.hex:iavrdude: Version 6.3, compiled on Sep 12 2016 at 15:21:49
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "/data/arduino/arduino-1.6.12/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/maco/.avrduderc"
User configuration file does not exist or is not a regular file, skippingUsing Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
