Sketch uses 930 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc7
Problem uploading to board. See Arduino Help Center for suggestions.
Yes! i switched the board, and i compile the same programme with necessary changes in tool menu, and i also try the same in NODEMCU, the same trouble shooting is accure
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
