hi everyone who reads this,
i hope somebody can help me with this.
i installed the program ARDUINO 1.8.18 i use the PLUS starter kit KS0538.
assembled the LED blinking project.
put in the code exactly as described in the tutorail.
Keyestudio 2021 Starter Kit
Project 2
LED_Blinking
http//www.keyestudio.com
int ledPin = 10; // defines numeric pin 10.
pinMode(ledPin, OUTPUT);// defines PIN with connected LED as output
digitalWrite(ledPin, HIGH); // turn on LED
delay(1000); // wait a second.
digitalWrite(ledPin, LOW); // turn off LED
After that i verify it, thats goes well after that i upload it. and then it gives errors
like this.
Arduino: 1.8.16 (Windows 10), Board: "Arduino Uno"
Sketch uses 936 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbe
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
i find this strange because the arrors says im using the "Arduino Uno" board but thats not the case.
The software type is what refers in the preparation.
Thank you much for your respond...
kind regards,
Chris
