Hello,
I am having issues with uploading to my Arduino.
I have tried the suggestions on the Arduino's troubleshooting webpage and I am still getting the same problem. I have tried many solutions posted online. I have tried two different boards (Nano and Uno) I get the same problem.
Pasted below is the error message I get. My OS information is also below.
Thanks in advance for the help.
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/maj/Desktop/arduino-1.8.9/hardware/tools/avr/bin/avrdude -C/home/maj/Desktop/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_125877/sketch_may14a.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/maj/Desktop/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/maj/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
[maj ~ 09:56 PM] : >lsb_release -a
No LSB modules are available.
Distributor ID: LinuxMint
Description: Linux Mint 19.1 Tessa
Release: 19.1
Codename: tessa
