Uploading MKR1000 through WI-FI only(without connecting the board to USB port)
hey guys!
I'm new to the forum section..
I have just started with my MKR1000 and its getting quite interesting.. I was wondering if i could do the sketch uploading without having the MKR board connected to the USB port.
As the MKR board has the Wi-Fi module,it would be cool if the code gets uploaded through Wi-fi when MKR is connected to an ordinary power source!
For ur info,i saw this kind of system in OMEGA-2 IoT microcontroller also..
Thanking in advance 4 ur replies..
Maybe this tutorial can help you
:wink:
thanks for your info..
it was difficult to follow the procedure given in the site..
But finally,i found that there was a built-in example (WiFi101-OTA),where u once upload through USB and then get your PC and MKR1000 connected to same WiFi and sketch update takes place Over-the-Air!
Hi
Are you able to upload sketched over the air on MKR1000.
can you share that example..
