Hello,
I am trying to use the elcrow smart watering kit 2.1 which contains the arduino leonardo board. When trying to upload the code, I get the following error
PORTS {} / {} => {}
Couldn’t find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board’s reset button after initiating the upload.
I have attached the full error report from the upload
Reading through the documentation on arduino, it looks like I have to press the rest button till the “uploading” message comes on the messages bar. I tried do this, but this did not solve the problem. Is there any particular sequence to be followed in resetting the part? How can this problem be solved?
error_msg_1023.doc (167 KB)
