Hi all,
I am having trouble uploading sketches to my new Portenta H7 and in addition is not recognized from Arduino IoT Cloud.
I have following information from IDE. The sketch is simple BLINK from examples.
I am using Arduino IDE 1.8.13.
Please HELP.
Thank you in advance
George
Arduino: 1.8.13 (Windows 10), Board: "Arduino Portenta H7 (M7 core), 1MB M7 + 1MB M4"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\george\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\george\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Electronics\Arduino\libraries -fqbn=arduino:mbed_portenta:envie_m7:split=50_50 -vid-pid=2341_025B -ide-version=10813 -build-path C:\Users\george\AppData\Local\Temp\arduino_build_851205 -warnings=none -build-cache C:\Users\george\AppData\Local\Temp\arduino_cache_792184 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.dfu-util.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.openocd.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\george\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\george\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Electronics\Arduino\libraries -fqbn=arduino:mbed_portenta:envie_m7:split=50_50 -vid-pid=2341_025B -ide-version=10813 -build-path C:\Users\george\AppData\Local\Temp\arduino_build_851205 -warnings=none -build-cache C:\Users\george\AppData\Local\Temp\arduino_cache_792184 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.dfu-util.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.openocd.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'envie_m7' from platform in folder: C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1
Using core 'arduino' from platform in folder: C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1
Detecting libraries used...
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\sketch\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\sketch\Blink.ino.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\george\AppData\Local\Temp\arduino_build_851205\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\sketch\Blink.ino.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7\variant.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\variant.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-gcc" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\arm_hal_random.c.o" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\arm_hal_random.c"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-gcc" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\itoa.c.o" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\itoa.c"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\main.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\main.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\Serial.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\Serial.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\WMath.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\WMath.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\Tone.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\Tone.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\wiring.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\Interrupts.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\Interrupts.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\pinToIndex.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\pinToIndex.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\abi.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\abi.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\wiring_analog.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_analog.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\wiring_digital.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_digital.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\wiring_pulse.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_pulse.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\wiring_shift.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_shift.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\USB\PluggableUSBDevice.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\USB\PluggableUSBDevice.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\USB\USBCDC.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\USB\USBCDC.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\USB\USBSerial.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\USB\USBSerial.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\api\Common.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\Common.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\api\IPAddress.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\IPAddress.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\api\PluggableUSB.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\PluggableUSB.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\api\Print.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\Print.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\api\Stream.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\Stream.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\api\String.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\String.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\as_mbed_library\variant.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\as_mbed_library\variant.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/defines.txt" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/cxxflags.txt" -MMD -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -DARDUINO=10813 -DARDUINO_PORTENTA_H7_M7 -DARDUINO_ARCH_MBED_PORTENTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7" -DCM4_BINARY_START=0x08100000 "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated" "-IC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino" "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/includes.txt" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\cores\arduino\mbed\platform\cxxsupport\mstd_mutex.cpp" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\mbed\platform\cxxsupport\mstd_mutex.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\arm_hal_random.c.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\itoa.c.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\Interrupts.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\Serial.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\Tone.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\USB\PluggableUSBDevice.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\USB\USBCDC.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\USB\USBSerial.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\WMath.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\abi.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\Common.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\IPAddress.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\PluggableUSB.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\Print.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\Stream.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\api\String.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\as_mbed_library\variant.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\main.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\mbed\platform\cxxsupport\mstd_mutex.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\pinToIndex.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_analog.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_digital.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_pulse.cpp.o"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\core.a" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\wiring_shift.cpp.o"
Archiving built core (caching) in: C:\Users\george\AppData\Local\Temp\arduino_cache_792184\core\core_arduino_mbed_portenta_envie_m7_split_50_50_5b6efb0a9863d9478b6ee7c2e275eca1.a
Linking everything together...
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -E -P -x c -DCM4_BINARY_START=0x08100000 "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/linker_script.ld" -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205/linker_script.ld"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" "-LC:\Users\george\AppData\Local\Temp\arduino_build_851205" -Wl,--gc-sections -w -Wl,--as-needed -DCM4_BINARY_START=0x08100000 "@C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/ldflags.txt" "-TC:\Users\george\AppData\Local\Temp\arduino_build_851205/linker_script.ld" "-Wl,-Map,C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.map" --specs=nosys.specs -o "C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.elf" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\sketch\Blink.ino.cpp.o" "C:\Users\george\AppData\Local\Temp\arduino_build_851205\core\variant.cpp.o" -Wl,--whole-archive "C:\Users\george\AppData\Local\Temp\arduino_build_851205/core\core.a" "C:\Users\george\AppData\Local\Arduino15\packages\arduino\hardware\mbed_portenta\2.6.1\variants\PORTENTA_H7_M7/libs/libmbed.a" -Wl,--no-whole-archive -Wl,--start-group -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.elf" "C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.bin"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.elf" "C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.hex"
"C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-size" -A "C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.elf"
Sketch uses 131448 bytes (16%) of program storage space. Maximum is 786432 bytes.
Global variables use 62080 bytes (11%) of dynamic memory, leaving 461544 bytes for local variables. Maximum is 523624 bytes.
Forcing reset using 1200bps open/close on port COM7
PORTS {COM7, COM18, COM19, } / {COM18, COM19, } => {}
PORTS {COM18, COM19, } / {COM18, COM19, } => {}
PORTS {COM18, COM19, } / {COM4, COM18, COM19, } => {COM4, }
Found upload port: COM4
C:\Users\george\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1/dfu-util --device 0x2341:0x035b -D C:\Users\george\AppData\Local\Temp\arduino_build_851205/Blink.ino.bin -a0 --dfuse-address=0x08040000:leave
dfu-util 0.10-dev
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to dfu-util / Tickets
Opening DFU capable USB device...
Device ID 2341:035b
Device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 011a
Device returned transfer size 4096
DfuSe interface name: "Internal Flash "
Downloading element to address = 0x08040000, size = 133496
Erase [======================= ] 92% 122880 bytesWarning: Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release
Error during special command "ERASE_PAGE" get_status
