Hello,
I recently bought a arduino mega 2560 and im trying to upload marlin firmware on it (this one) but I have a little problem, I keep getting the out of synch error.
running windows 7 64-bit, tried numerous drivers, tried arduino 0023, 1.0.1, 1.6.4 and 1.6.7. on every version I added the sanguino addon. tried diffrent cables and tried pressing and/or holding the reset button on diffrent times.
I also tried this with 2 diffrent mega boards. I know there are a lot of threads on this but I can't find a solution.
Also I added the error message, hope I could give some more info
Arduino: 1.6.4 (Windows 7), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
Build options changed, rebuilding all
Sketch uses 86,354 bytes (66%) of program storage space. Maximum is 130,048 bytes.
Global variables use 3,668 bytes (22%) of dynamic memory, leaving 12,716 bytes for local variables. Maximum is 16,384 bytes.
E:\UTK\arduino-1.6.4\hardware\tools\avr/bin/avrdude -CE:\UTK\arduino-1.6.4\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\Joram\AppData\Local\Temp\build2052410963142888245.tmp/Marlin.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "E:\UTK\arduino-1.6.4\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1e
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
