uploading problem
i am getting error while uploading the program, the error message is
“Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.”
Kindly give the solution for it
There is no error message?...
That is not an error message. That indicates that your sketch has compiled successfully. If that was the only output, it would appear that you clicked verify (which only compiles the code) instead of upload (which compiles the code and then uploads it).
