Uploading Problem
what should i do for this?
Don’t post pictures of text! That’s very unhelpful. You need to post the full output using code tags (</> button on the toolbar).
./opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -build-path /tmp/622600046/build -hardware opt/arduino-builder/hardware -hardware ./opt/cores -tools opt/arduino-builder/tools -tools ./opt/tools -built-in-libraries opt/libraries/latest -libraries /tmp/622600046/pinned -libraries /tmp/622600046/custom -fqbn arduino:avr:uno -build-cache /tmp -logger humantags -verbose=false /tmp/622600046/Mortors_Codes_For_a_Car
Sketch uses 1094 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Flashing with command:C:/Users/THARINDU/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude.exe -CC:/Users/THARINDU/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:/Users/THARINDU/AppData/Local/Temp/arduino-create-agent672921704/Mortors_Codes_For_a_Car.hex:i
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc2
avrdude done. Thank you.
please help me
So ensure you have nothing connected to pins 0 and 1 to start with.
Then go through this post to be able to tell us a little more.
