Uploading Problem
When i am trying to upload any code (even an empty page) codes don't be uploaded.
Here is the error message:
Archiving built core (caching) in: C:\DOCUME~1\AYDN~1\LOCALS~1\Temp\arduino_cache_213388\core\core_arduino_avr_uno_fd040c28ca717db04400ddff4ecd4334.a
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x60
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
What should i do?
You should start by reading THIS PAGE then adding a lot more information please.
I have found a similar issue on MAC OSX HIGH SIERRA.
I have been regularly programming a mega2560, NodeMCU, WeMOS, as well as UNOs.
When I installed 1.8.5 I started getting serial comms problems, on all devices.
The report from Arduino was that it could not program the device - serial timeout!
Here is how I fixed it for all devices -
Tools>Port>(click on the enumerated port - usually ticked)
This closes any associated Serial Monitor window.
Not sure if the next step is strictly needed:
Now you can upload, wait til finished.
Then -
Tools>Serial Monitor
Success.
