Uploading Problem
i receiving this error why
i am using Windows & and Arduino 022
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
OK
We need alittle more information.
Which board?
What Windows version?
Did it ever work?
Are you sure you have selected the correct serial port and board in the Arduino menu.
Hello All,
I am a total Newb at Arduino. I have purchased a Osepp Uno card from Fry's electronics. I was having problems getting it to load, but found that I had to set it for the ATMega 328 card and got communications. However I have tried to get it to reconnect this morning and have had no luck. I keep getting this mesage ; avrdude: stk500_getsync(): not in sync: resp=0xff[/font[/color]]. I have reinstalled the loader, and adjusted the com port to 2. (it was 11 however someone posted it doesn't like anything above 10) I am running windows XP. I even unintalled and reinstalled the port and it shows it working o.k. I get the TX and RX lights to blink together quickly bu it fails with the same message over and over again. My program works, I just cant seem to get comms.
Any help would be appreciated.
Binary sketch size: 2048 bytes (of a 30720 byte maximum)
Well I found the problem. It seems the power pin on my LCD was Dodge and would not let me reprogram it. As soon as I corrected the LCD issue, I could reprogram it without a hitch. Go figure. After hours of scouring the net, that solution never came up.
