Uploading Sckatch via WIFI
I am using Mac with OSX version 10.9.3 and Arduino IDE 1.5.6-r2. Using this configuration i cannot see the option to upload the sckatch via wifi. It works when i upload the sckatch via USB.
When i connected my Y'un to a PC i was able to use the WiFi option so i assume the problem is not with the Y'un board.
I am quite newbi in Linux so detailed explanation will be appreciated.
TX
Hi!
The good news is, that it's exactly the configuration I use and it works over here.
Are you able to connect to Yun using Safari?
If yes, start IDE and select the Yun board. Have a look to the port menu. Which entries do you see?
Hi Mamu,
Yes no problem connecting with safari. Maybe it's the Y'un openwrt version. which version are you using?
see attached my version (the latest one)
Did you made any changes to the openwrt Yun configuration files?
It worked with the original Linino image and with the new openwrt image. I made no changes to make it work.
As I can see on your screenshot you use the ip notation. Have you tried using arduino.local http address notation?
It was a problem with the router. I performed a complete reset and reconfigure the router and it start working.
It's strage because it was working with windows with the old router config. Now it is working also with the Mac.
Thanks for your help Mamu!
