uploading sensor data to e.g. Excel
Hi Everyone
I'm a total newcomer with an interest in data logging but with no recent programming experience. I'm seeing incoming sensor data on the serial monitor but I can't find any advice on importing it to e.g. Excel or a similar graphing program.
Can anyone point me in the right direction?
Thanks
Search CSV
Look at the Realterm serial monitor and saving data.
http://realterm.sourceforge.net
See Capture in Realterm.
Data Logging
Using Capture and SendFile from the commandline, you can log data and control intruments directly from the commandline, without extra software.
realterm.exe senddly=10000 sendrep=0 sendfile=commands.txt capture=results.txt
This will send "commands.txt" endlessly, with a 10sec pause between sends, and capture the replies to "results.txt". This is all you need to do to turn (say) and RS232 multimeter into a datalogger.
I have written a excel macro that uses the serial port to get data directly. Another solution would be to write a Pc side program in processing to do the same thing
The following link will be useful for you too:
If you use an Arduino leonardo you can have it type directly into the spread sheet by making it look like an external keyboard.
