Uploading sketch problem
HI, I am brand new to arduino and I am in need of some assistance. When I try to upload the sketch I get a "Problem uploading to board." error. Here are the error messages:
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\Dr-Wh\Desktop\Full_Phaser_1\Full_Phaser_1.ino: In function 'setup':
C:\Users\Dr-Wh\Desktop\Full_Phaser_1\Full_Phaser_1.ino:35:21: warning: iteration 10 invokes undefined behavior [-Waggressive-loop-optimizations]
pinMode(ledPin*,OUTPUT);*
    C:\Users\Dr-Wh\Desktop\Full_Phaser_1\Full_Phaser_1.ino:33:3: note: containing loop
  • for (int i = 0; i < 11; i++)*
    C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino\main.cpp: In function 'main':
    _ pinMode(ledPin*,OUTPUT);_
    _
    ^_
    _
    for (int i = 0; i < 11; i++)_
    _
    ^_
    Sketch uses 5150 bytes (16%) of program storage space. Maximum is 30720 bytes.
    Global variables use 285 bytes (13%) of dynamic memory, leaving 1763 bytes for local variables. Maximum is 2048 bytes.
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x16
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x16
    Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
    _
    "Show verbose output during compilation"*_
    option enabled in File -> Preferences.
    Any help is appreciated thanks :slight_smile:
What programmer do you have selected? This is the one you should have selected if I remember correctly. Can be found in: Tools -> Programmer in the Arduino IDE v1.8.5
Get rid of the window store app and download the proper IDE.
Many people have mentioned issues with the APP version and most seem to be OK once they go to the real IDE.
The programmer wont matter for the NANO as the IDE will use what it needs in that regard.
What usually works for most is to get the official CH340/341 drivers from here
Mileage on the next two steps varies a little but I always do both and have had no issues.
Turn OFF driver enforcement
Install the drivers as ADMINISTRATOR
Both those steps turn up easy in a google search.
You should be seeing the CH340 device in a similar fashion to the picture below (but not as many LOL)
