uploading sketch using ethernet on mega and ethernet shield
I am trying to use the arduino mega with a ethernet shield and trying to upload a sketch using ethernet on the mega. I am using a uno as a ISP. I am following this link to do this - http://www.freetronics.com/pages/how-to-upload-a-sketch-to-your-arduino-via-a-network. I downloaded the 0.3beta version of tftp bootloader for that.
I burnt the ISP sketch on uno, made the connections to the mega, but got errors while trying to burn the bootloader using the IDE.
avrdude: ser_recv(): programmer is not responding
In the bootloader code, I changed the spi pin numbers to match the ones on mega and replaced the hex file, but that didnt work. There was also a suggestion to put a 10mfd cap between reset and ground on uno but that also didnt work...
Any idea as to what do i need to do to make it work.
Post a picture of your cabling and post the modified bootloader code.
net.h
//Offset of pin INSIDE PORTB!! (not absolute)
#define SCK_PIN 1 //PB5
#define MISO_PIN 3 //PB4
#define MOSI_PIN 2 //PB3
#define SS_PIN 0 //PB2
Did I get your approach correctly? You want to program a TFTP bootloader to an Arduino Mega2560 by taking an Arduino UNO with an ISP sketch applied?
In this case you haven't wired it correctly. The UNO must have the possibility to reset the Mega2560, so the Mega's reset pin has to be connected to a GPIO pin on the UNO (example with two UNOs: http://arduino.cc/en/Tutorial/ArduinoISP)
that is correct.
How would uno know to which pin i have connected the reset of mega. Do I need to make a code change somewhere.
You must load an ISP sketch on the UNO and in this source code the pin for resetting the target controller is defined.
thanx, the burning the bootloader was successful. The link i am following says once its done, the led connected to pin 9 and gnd should blink at 1hz... for me it just stays on, though the ide says burning was successful.
I also changed the IP address for the gateway, arduino and the subnet mask in the net.c file and copied the hex file in the arduino tree for the bootloader, to match my current setup. My router is at 192.168.0.1, pc at 192.168.0.5 and the arduino at 192.168.0.10. I changed my router setup to hardcode the ip address for the shield mac address. After doing all this, when I ping the arduino from the pc, I get the destination host unreachable.
I am running fedora 18.
The compiled bootloader is for an ATmega328 and not for an ATmega2560. You have to compile the package yourself and install it in the appropriate folder. Have you done that? Post the modified Makefile.
I hadnt changed the makefile. I changed the device id to atmega2560. rest of the file is the same, do I need to change anything else in there. I tried the whole thing again, led still doesnt blink (led and resistor work otherwise), I can burn the bootloader, but cannot ping the mega.
Makefile:
# Name: tftp.c
# Author: Denis PEROTTO, from work published by Arduino
# Copyright: Arduino
# License: GPL http://www.gnu.org/licenses/gpl-2.0.html
# Project: eboot
# Function: tftp implementation and flasher
# Version: 0.1 tftp / flashing functional
# Important make targets:
# install			: flash bootloader using AVR ISP MkII
# disasm			: output disassembly of bootloader
# readback		: read back flash contents to read.hex
#DEVICE     = atmega328p
DEVICE     = atmega2560
CLOCK      = 16000000
PROGRAMMER = -c usbtiny -P usb
OBJECTS    = main.o net.o tftp.o validate.o debug.o
APPOBJECTS = app.o
# 2Kword boot block
FUSES      = -U efuse:w:0x05:m -U hfuse:w:0xd8:m -U lfuse:w:0xff:m
#FUSES      = -U efuse:w:0x05:m -U hfuse:w:0xd9:m -U lfuse:w:0xff:m
LDFLAGS = -Ttext=0x7000
# 1Kword boot block
#FUSES      = -U efuse:w:0x05:m -U hfuse:w:0xda:m -U lfuse:w:0xff:m
#LDFLAGS = -Ttext=0x7800
# 512 word boot block
#FUSES      = -U efuse:w:0x05:m -U hfuse:w:0xdc:m -U lfuse:w:0xff:m
#LDFLAGS = -Ttext=0x7C00
# 256 word boot block
#FUSES      = -U efuse:w:0x05:m -U hfuse:w:0xde:m -U lfuse:w:0xff:m
#LDFLAGS = -Ttext=0x7E00
# Extended Fuse Byte:
# 0x05 = 0 0 0 0 0 1 0 1
#            |       +------ BODLEVEL Brownout detect at 2.5 to 2.9V
#            +-------------- Unused
# High Fuse Byte:
# 0xD8 = 1 1 0 1 1 0 0 0 <-- BOOTRST  Reset to bootloader
#        | | | | |  +------- BOOTSZ   2Kword bootloader, 0x3800-0x3FFF, reset at 0x3800
#        | | | | +---------- EESAVE   EEPROM erased in chip erase
#        | | | +------------ WDTON    Watchdog timer off
#        | | +-------------- SPIEN    SPI programming enabled
#        | +---------------- DWEN     DebugWIRE disabled
#        +------------------ RSTDISBL External Reset enabled
# Low Fuse Byte:
# 0xFF = 1 1 1 1 1 1 1 1
#        | |  |     +------- CKSEL    Low power crystal, 16Kck delay
#        | |  +------------- SUT      65ms delay
#        | +---------------- CKOUT    No clock out
#        +------------------ CKDIV8   No divide by 8 prescaler
AVRDUDE = avrdude $(PROGRAMMER) -p $(DEVICE)
# Compiler options to shrink bootloader size
CCOPT = -Os
CCOPT += -mno-interrupts #Interrupts will not be supported in code
CCOPT += -mshort-calls
CCOPT += -fno-inline-small-functions
CCOPT += -fno-split-wide-types
CCOPT += -Wl,--relax
# do not use cause great instability??
#CCOPT += -nostartfiles
# These optimisations have no effect, so turned off
#CCOPT += -mtiny-stack
#CCOPT += -ffreestanding
#CCOPT += -fpack-struct
#CCOPT += -fno-jump-tables
COMPILE = avr-gcc -Wall $(CCOPT) -DF_CPU=$(CLOCK) -mmcu=$(DEVICE)
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
# symbolic targets:
all:	main.hex
%.o: %.c
	$(COMPILE) -c $< -o $@
%.o: %.S
	$(COMPILE) -x assembler-with-cpp -c $< -o $@
# "-x assembler-with-cpp" should not be necessary since this is the default
# file type for the .S (with capital S) extension. However, upper case
# characters are not always preserved on Windows. To ensure WinAVR
# compatibility define the file type manually.
%.s: %.c
	$(COMPILE) -S $< -o $@
%.bin: %.elf
	rm -f $@
	$(OBJCOPY) -j .text -j .data -O binary $< $@
%.hex: %.elf
	rm -f $@
	$(OBJCOPY) -j .text -j .data -O ihex $< $@
# Programming targets - which are set up for a TinyUSB programmer
flash:	main.hex
	$(AVRDUDE) -U flash:w:main.hex:i
quickflash:	main.hex
	$(AVRDUDE) -V -U flash:w:main.hex:i
fuse:
	$(AVRDUDE) $(FUSES)
# Xcode uses the Makefile targets "", "clean" and "install"
install: flash fuse
quickinstall:quickflash fuse
clean:
	rm -f *.hex *.elf *.bin *.o
# Bootloader
main.elf: $(OBJECTS)
	$(COMPILE) -o main.elf $(OBJECTS) $(LDFLAGS)
# Targets for code debugging and analysis:
disasm:	main.elf
	$(OBJDUMP) -d main.elf
map:	main.elf
	$(OBJDUMP) -h main.elf
cpp:
	$(COMPILE) -E main.c
readback:
	$(AVRDUDE) -U flash:r:read.hex:i
The fuses should be as from boards.txt for the Mega2560:
FUSES = -U efuse:w:0xfd:m -U hfuse:w:0xd8:m -U lfuse:w:0xff:m
Have you checked that the generated file was transfered to the Mega2560 and not any other?
And next time, please use code tags!
tried with the new fuses. still same result. No led blink on pin 9... no ping.
I also see that when the bootloader is being burnt, the uno tx light is blinking rapidly, but no such luck on the mega, the rx is not lighting. so i guess the data is not making it to the mega. though avrdude reports success.
I also updated the boards.txt with relevant values in the /usr/share/arduino/hardware/arduino-tftpboot/boards.txt file but no impact.
This is the expected behavior because the UNO is using the USART interface to communicate with the PC while the UNO and the Mega communicate using the SPI interface which doesn't have an LED to check data is transmitted (it would be much to fast anyway).
I ask my question again: How do you check that the generated file was transfered to the Mega2560 and not any other? Have you activated the debug information during upload?
Edit: Did you also change SS_PIN in net.h? Pin 10 is on PB4 on the Mega and not PB2 as on the UNO.
I am using pin 53 for SS, so its set to 0. Here're the settings in net.h
#define SCK_PIN 1 //PB1 - pin 52
#define MISO_PIN 3 //PB3 - pin 50
#define MOSI_PIN 2 //PB2 - pin 51
#define SS_PIN 0 //PB0 - pin 53
But looks like the issue is that the SS pin 53 isnt connected to anything. For uno, its pin 10, but that is also the reset pin on uno in the ISP program. Should i change the reset pin to something else in Arduino ISP sketch and connect 53 on mega to 10 on uno?
Not sure I understand your question. the system connected is mega to uno. the debug output is on while doing the upload.
output from upload, its quite big and i had to trim it. Let me know if you need to see the whole output and I will send it across by some other way.
avrdude -v -v -v -v -patmega2560 -cstk500v1 -P/dev/ttyACM0 -b19200 -e -Uefuse:w:0xfd:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xFF:m
avrdude: Version 5.11.1, compiled on Jul 19 2012 at 01:16:45
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude/avrdude.conf"
         User configuration file is "/home/vikas/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x1e9801
avrdude: reading input file "0xfd"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfd:
avrdude: load data efuse data from input file 0xfd:
avrdude: input file 0xfd contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: verifying ...
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xd8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd8:
avrdude: load data hfuse data from input file 0xd8:
avrdude: input file 0xd8 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
avrdude -v -v -v -v -patmega2560 -cstk500v1 -P/dev/ttyACM0 -b19200 -Uflash:w:/usr/share/arduino/hardware/arduino-tftpboot/bootloaders/arduino-tftpboot/arduino-tftpboot-bootloader-m328.hex:i
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: reading input file "/usr/share/arduino/hardware/arduino-tftpboot/bootloaders/arduino-tftpboot/arduino-tftpboot-bootloader-m328.hex"
avrdude: writing flash (32086 bytes):
Writing | ############################################avrdude: Send: U [55] . [00] 8 [38]   [20]
# | 100% 20.22s
avrdude: 32086 bytes of flash verified
Have you really name your bootloader compiled for the ATmega2560 "arduino-tftpboot-bootloader-m328.hex"?
You cannot use pin 53 for the SS because the Ethernet Shield is using pin 10 for that.
The UNO is not connected to the Ethernet Shield and is not running the TFTP-Bootloader so it's not relevant. You don't have to change anything in the wiring, you have to change the software appropriately.
Hello, I am interested also to loading the sketch from the network, with Arduino Mega.
Were you able to upload it and make it work?
thanks
I had been looking all over the Internet for a solution to the same dilemma. As I understand it, one must have an AVR ISP MkII programmer in order to burn any bootloader to the mega2560 because of its large memory. The UNO ISP sketch isn't able to address the extended memory of the 2560.
Is this correct?
I really do not want to spend the $30 that they cost (or whatever it is). Anyone in Phoenix have one I could barrow for, uhh, idk, 10 minutes?
JoeyPhxAZ:
Is this correct?
HI JoeyPhxAZ!!!
Have you find a solution to upload your sketch over tftp on your Arduino Mega 2560.
I find a solution for it, but I cannot Upload sketch over 28 Kb of size...
Tnk!
