? uploading sketches?
Can 2 sketches be uploaded on the UNO at the same time. If so, will they function at the same time?
Thanks for the help with the basics!
Simple as that.
You can, however, write a single sketch that controls multiple independent things concurrently.
If I merge my two sketches, that would work?
JBTo:
Impossible to give a definite answer without knowing what the sketches do, but in general yes, that approach is possible.
I merge the two sketch and they upload fine. One sketch handles a keypad imput to operate a locking system. The other handles a fingerprint scanner that also operated the same locking system.
When uploaded, it runs the keypad, but does not power the fingerprint device.
Any sugestions?
The merged code fallows:
#include <Password.h>
#include <Keypad.h>
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
 #include <SoftwareSerial.h>
#else
 #include <NewSoftSerial.h>
#endif
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 12, 11, 10 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int getFingerprintIDez();
int led = 13;
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(2, 3);
#else
NewSoftSerial mySerial(2, 3);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(led, OUTPUT);
  Serial.println("fingertest");
  // set the data rate for the sensor serial port
  finger.begin(57600);
   keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  keypad.setDebounceTime(100);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
  Serial.println("Waiting for valid finger...");
void loop()                     // run over and over again
    keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
    case PRESSED:
      Serial.print("Pressed: ");
      Serial.println(eKey);
      switch (eKey){
        case '#': guessPassword(); break;
         default:
               password.append(eKey);
void guessPassword(){
     Serial.print("Guessing password... ");
     if (password.evaluate()){
           Serial.println("VALID PASSWORD "); //
           digitalWrite(5, HIGH);
           digitalWrite(4, HIGH);
           digitalWrite(4, LOW);
             delay(25000);
           digitalWrite(5, LOW);
              password.reset(); //resets password after correct entry
     }else{
           Serial.println("INVALID PASSWORD ");
              password.reset(); //resets password after INCORRECT entry
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerFastSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  // found a match!
  digitalWrite(13, HIGH);
  delay(25000);
  digitalWrite(13, LOW);
  return finger.fingerID;
